Yes Sir it did
prior to installing the trailer box here is the combo that I could get to work. LED's in front, LED tail/brake, Incandescent tail/turn. with this set up I had no bleed thru. So my hope is that I can add load resistors to the rear tail/turns (that are now also brake lights) to get back to a load in which it recognizes. for the Tail light/oil "Warning light" unless I run a incandescent 1157 in the main tail I'm not sure how to make this go out without unplugging the "warning" bulb thus also removing my oil pressure light. I'd like to retain this light.
I got the flasher from Amazon brand called keep it clean.... it says right on it no load LED flasher. But also states it will work with up to 10 1157 bulbs
prior to installing the trailer box here is the combo that I could get to work. LED's in front, LED tail/brake, Incandescent tail/turn. with this set up I had no bleed thru. So my hope is that I can add load resistors to the rear tail/turns (that are now also brake lights) to get back to a load in which it recognizes. for the Tail light/oil "Warning light" unless I run a incandescent 1157 in the main tail I'm not sure how to make this go out without unplugging the "warning" bulb thus also removing my oil pressure light. I'd like to retain this light. I got the flasher from Amazon brand called keep it clean.... it says right on it no load LED flasher. But also states it will work with up to 10 1157 bulbs
