Tranny Questions
    • 8736
    Yes, correct.
    Also, when reassembling, make sure clip #25 is nice and straight when installing, otherwise 2nd gear will not spin freely and may cause notchy shifting. It can be hammered straight on a vise anvil.
    • gaillarry
      • 32
      • Ontario Canada
      Thanks, I just wanted to confirm I'm moving the right part.
      One of the shift forks ( #1)has a few deep scrapes in it, I suspect from the loose circlip and washer I found in the oil pan. Luckily I have a spare.
      1980G Tourer
        • 8736
        The shift forks usually wear out like that from someone holding down the shifter trying to keep the tranny from slipping out of gear due to the worn dogs/slots.
        • gaillarry
          • 32
          • Ontario Canada
          Undercut the gears but I think not enough?
          1980G Tourer
            • 8736
            I'd probably go a little more angle, and no rounded edges.
              U wanna hold that same angle grinding till it comes to the outer edge. Leave the edge squared at the end. ....Nate, that washer/circlip is what happens when it start jumpin' out of gear. Shift fork seems to drag on that shaft jerking it causing that circlip to come off. I'm sure that shift fork gets to slammin' back and forth pretty good ......tat....tat....tat....you could just imagine what's goin' on in there.....
              • gaillarry
                • 32
                • Ontario Canada
                Did a regrind they look a lot better.
                Question about the washer and circlip shown in the pic, the washer moves back/forth on the shaft, does it not lock down somehow?
                1980G Tourer
                  • 8736
                  That washer should be flat against 1st gear and the circlip holds it there by sitting in a groove in the countershaft. First gear is stationary on the countershaft, it only freewheels, it doesn't slide side to side. Once you have the countershaft and gears properly installed in the case, you'll see that that washer can't go anywhere.
                    Nate, I have doen this repair more than a few times on at least four different engines. Two were pretty abused, and both of those had that circlip and washer in the oil pan. On one, the oil pump idler gear slid out and got chewed by the clutch gears....very ugly.
                    • gaillarry
                      • 32
                      • Ontario Canada
                      Thanks for all the input. Getting the gears and shift forks in place is a pain but it now shifts smoothly into 2nd gear
                      1980G Tourer
