Originally posted by Rasputin
View Post
tach lens removal
Don
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
2005 V-Star 1100 Classic
Three white wires and a yellow one if my memory is any good. The wires come up from the alternator and join the harness there. Usually if the connection is bad, there is everything from tach bouncing to fires. Mine was melted so bad I could not believe it did not start a fire. It can be as simple a fix as butt connecting the wires to as complcated as you like nut the connector is available as well as other fixes.2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
In my case, the jumpy tach was corroded connections on the PC board inside the tach itself. I had to disassemble the tach, clean/reheat the solder joints and that fixed it. YMMV2H7 (79)
3H3
Originally posted by ddragon63 View Post. I would think to roll the edge back on installation a wood body dolly and small body hammer oughta do the trick to not blunder it too bad...
Ooooh no! You do not want to start hitting the thing with a hammer, even a small body hammer. The needle is old and plastic, and has seen a lot of sunlight, and you know what happens to plastic in the sun. And there are delicate internal workings that do not like harsh vibrations, even from small body hammers. Thats why they mounted the instruments in rubber bushings. Crimp it back with some padded pliers.
CZ
There's been a couple of different methods posted for repairing these... there's a pretty decent trick fix with some big shrink tube linked in the last post of this thread: http://www.xs11.com/forum/showthread...=speedo+repair
Somewhere there's a post (which I can't find) where the lister split the main housing (not disturbing the bezel) inside the outer shell on a 'sacrificial' gauge, and overlapped the two housings. You do need an extra gauge for this, but you do end up with a gauge that can now be disassembled easily. Good use for that 85mph unit you swapped out....
But it's nearly impossible to remove/reinstall the OEM bezel without leaving some trace of your work.Fast, Cheap, Reliable... Pick any two
Originally posted by CaptonZap View PostOoooh no! You do not want to start hitting the thing with a hammer, even a small body hammer. The needle is old and plastic, and has seen a lot of sunlight, and you know what happens to plastic in the sun. And there are delicate internal workings that do not like harsh vibrations, even from small body hammers. Thats why they mounted the instruments in rubber bushings. Crimp it back with some padded pliers.
CZDon
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
Originally posted by crazy steve View PostThere's been a couple of different methods posted for repairing these... there's a pretty decent trick fix with some big shrink tube linked in the last post of this thread: http://www.xs11.com/forum/showthread...=speedo+repair
But it's nearly impossible to remove/reinstall the OEM bezel without leaving some trace of your work.Don
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
Hi Dragon,
what they all said; getting the glass on and off is not a job for the faint-hearted so lets hope the fluctuation is in the wiring, not the instrument.
But I know a trick to dry it out. Shove it in a vacuum chamber.
Sufficiently low air pressure drops the boiling point down to below ambient so the water droplets flash to steam which gets sucked away.Fred Hill, S'toon
I have a good set of repair instructions. They're in PDF format. PHOTOBUCKET won't support them. Is there a way to post it here?
Here is the heat shrink bezel link:
http://xs650temp.proboards.com/index...5&page=1#39501Marty (in Mississippi)
