Which way or does it matter?
    • 3189
    Which way is this spring installed or does it matter?
  • ddragon63
    • Jan 2012
    • 1101
    • Ridgefield, WA
    don't think it matters... but personally i would put the flat part away from me so the s bend leg is easier to get to for future removal
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
      • 9980
      If it wasn't so cold out I'd go look to be sure.
      Is that the shift return spring?
        • 7941
        It's the torsion spring for the shift shaft. I don't remember which way it goes.
          • 3189
          Funny boy BA80. Yes it is the shift return spring. Figured anyone qualified to answer would know what it was so I neglected to put that in the question. I do know you are knowledgable in this area so no offense meant.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            • Fort Myers, Florida
            In
            If this is it, looks like the flat side facing in:
            http://www.boats.net/parts/search/Ya...DAL/parts.html
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              • 3189
              Same picture as I have been looking at. If you look at the pics I posted you can see why my confusion. Looks different than a 2 D pic on a fiche.
                • 9980
                OK. That's one thing I'm not real familiar with. I just went and looked but all the engines I have (7 not counting what's running) only one has that cover off and that particuar part is gone.
                In the parts fiche it looks to me like the curved leg goes inside. It should only fit right ONE WAY I would think. That curved leg ain't there for no reason.
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  Out
                  That was a typo, looks like OUt for the flat side in the picture as the moving part it drives is on the outside, makes sense to me, but should only fit in right one way anyway So should be clear when installing I would think Or to be correct, should go in the way it came out!
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                    • 3189
                    Thanks for the input. It moves the shifter BOTH WAYS, so it could be either way. If it was clear I would not have asked! It has been about a year since it was apart so my memory is a bit jaded as to the way it came out.
                      All of mine have been installed with the legs against the engine case, or flat side to the back.
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        It is a shame the pic isent more conclusive, it looked to me like the flat side was facing out, and the inside was the bent leg, but not as clear as it could be in the pic.
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                          Well, I sit corrected...by my own picture...
                          That is a pic I took as I disassembled Thunderstruck for the 2nd gear repair. Looking at it, appears the legs are against the shift paw.
                            • 3189
                            The thing i am needing to know is which way does the spring fit under that shifter pawl. I did a second gear fix and the bike is not shifting down quite right. It has been suggested that that spring may be weak. I was wondering if it could have been installed assbackwards and that may be the problem. The thing holds the gears ok it just does not like to downshift without pl;aying a bit. I do not think the grinding of the gear was wrong, but who knows.
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              A new one is 5 bucks
                              http://www.boats.net/parts/detail/ya...-29361-00.html
                              From looking at you pic's, your is worn due to the angle of the spring shafts, JAT
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
