Airbox reassembly
  • mack
    • 2411
    • Ontario, Canada
    Airbox reassembly
    I've seen this asked a few times so since that's what I did yesterday I figure it couldn't hurt. After you have cleaned everything, mouse nests etc
    1. Start by laying out all your components
    2. Attach side trim/mouldings
    3. Put in numbers 1 & 4 velocity stacks
    4. lossely attach frame brackets with short screws only
    5. Insert and attach crankcase breather hose manifold
    6. Insert 2&3 velocity stacks
    7. Insert long screws and spacers
    8. Fit upper bracket by slipping the rear portion in first the push out on the long side until it falls in flush with upper box rim. A little dexterity and patience is require here as you have to ensure the top of the spacers and screws line up with the fitted nut holes in the bracket.
    9. Take a small flat tipped screw driver and work around the edges of the snorkle until it fits into the slotted groove of the bracket
    10 Secure the bracket to the upper airbox with the clamp and two screws
    11 Insert wing nuts and keepers into the airbox lowwer and test fit the two halfs
    If you find that there is a larger than acceptable gap between the two halfs, then just remove the wing nuts and grind them shorter by an 1/8 th or so. Dont forget to put a nut on them first as grinding will mess up the starting threads. Removing the nut restores the threads.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Nice
    Nice job BikerPhil had a good idea, he cut the loop off the upper bracket and cut the outside part of the snorkle off, so when you have to remove the carbs, you can slide the whole airbox out first to make the rest easy Thinking about doing it on mine as I remove the carbs almost daily
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
      Sounds like something someone would bitch about a PO for.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Yep
        Yep, but thanks to FeeBay and pods, there are plenty out there cheap if you want to have both styles when you sell it, here is one for 9 bucks ButItNow
        http://www.ebay.com/itm/80-XS1100-XS...sories&vxp=mtr
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • mack
          • 2411
          • Ontario, Canada
          Air box
          Steve did a mod to his, in which he basically gutted the internals completely and made a cool air filter adaptatyion. I've been waiting for him to repost on performance improvemnt. By the way I forgot to mention this but this box was off the LH so the vent holes are plugged, same steps would apply for a 78/79 box, but I would add that for thoughs, ensure the vent holes are unobstructed before reassembly step #1.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
            I would not install the crankcase gas manifold. They are for emissions, I know, but if you put oily dirty air into the carb inlets, that isn't good in the long term for emissions, is it?
              There a few schools of thought on that... one is that helps reduce the crankcase pressure and help with seal life as well as adding maybe a bit of power. As far as emissions, it's better to burn the vapor rather than just spew it into the air...
              I installed mine on my modded airbox, but did cut off the 4 tubes that go into the carb throats.
