Boy I feel lucky... other than my leaky petcock I have never had a fuel issue with mine. (knock on wood) I've left it parked for months on end in RES or ON sitting on the kickstand. if it sits longer than a month i have to switch it to Prime to refill the carbs to start it. but I've got a standard tank... no octy
Carbs d@#m pos!!
Don
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
2005 V-Star 1100 Classic -
are you using the "motorcycle" Lucas or just the regular stabilizer? I would assume the motorcycle stuff is designed for wet clutches. all my ATV buddies use itDon
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
2005 V-Star 1100 ClassicComment
Thanks
Thanks my brother, right now, 100 bucks is too much cash for me, I love the idea, but just cant spend the $$ right now
Thanks for all your help, I am thinking, drop the filters below the bowl hight to stop the draining from them, and shut off the petcocks before I shut off the bike. Just trying to do what I can on a nickel
Thanks though
OEM, I've had plenty of gas run out my airbox but never, as far as I know in the crankcase. My bike never goes on the centerstand unless I'm working on it, it resides under my workbench. That Pingle valve I run is perfect for the single fuel tap that I run, I'm sure you could rig up a second T connection for dual fuel taps. Anyway, it's the best $90 I've ever spent, piece of mind is priceless. Here they are if you decide to go that way....
http://www.amazon.com/gp/offer-listi...&condition=new1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
Oem
What floats you using, I read you had to bend the tangs considerably to achieve your height. If you are using the plastic crap it's 22.5mm to start. Brass work better with our carbs. Change your oil, get rid of the octy, turn your 'T"'s down, put in the stock fuel valves and needles, turn your gas on and off and ride the sh.t out of it.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
Brass
I have the OEM brass flosts, the bending was due to the new 920 neelles I installed based on recomedations on here
, will go back the the OEM metal needles next rebuild
What floats you using, I read you had to bend the tangs considerably to achieve your height. If you are using the plastic crap it's 22.5mm to start. Brass work better with our carbs. Change your oil, get rid of the octy, turn your 'T"'s down, put in the stock fuel valves and needles, turn your gas on and off and ride the sh.t out of it.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
For sure and cheap
Advance auto has inline cheap fuel shutoff valves that will be cheap untill you get money enough to buy more appropriate solution.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
http://s1184.photobucket.com/albums/z329/viperron1/Comment
