This project is on my "to do list" also... I haven't a clue the last time it was done. got the tool on order and the shim place on google bookmark... with hope and a prayer I'll just be sealing the valve cover back up and putting the tool in the box for use @ a later date. but somehow I doubt it will be that easy, nothing on this poor old dog has been that simple.
I know the zip tie is only plastic, but by putting it between the valve head and the seat, you're introducing some lateral forces on the valve head/stem....and with the springs pulling fairly strongly against it, without the same piece of zip tie on the other side of the seat...I would think there could be a tendency to bend the valve head....even just a little, it only takes a little to cause the valve to not seat completely and therefor not seal=comp leak!
JAT?
