How to remove and install your Cam Chain Tensioner CCT
  • ddragon63
    • Jan 2012
    • 1101
    • Ridgefield, WA
    Originally posted by JasonRedbeard
    Define "good oil." What's best for these bikes?
    <hides behind couch to avoid thrown objects>
    I'm gonna put my helmet on real quick before I answer your question
    I personally use good old Castrol 4T 20w-50. If they are out of that I'll use the Valvoline. Now my R1 gets Mobil1 racing 10w-40 only.... thats what its got since its birth. I'm not gonna tell you they are the best out there. All I'm saying is thats what I use. It hasn't let me down yet in any powersports machine I've owned.
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
      • 2071
      Something...
      ...that may be worth mentioning is the DIRECTION of ROTATION for the "less experienced", which is denoted by the arrow on the timing plate under the left side cover (shift side). Only turn the engine CLOCKWISE in order to have all slack in the cam chain at the tensioner area so that it, the slack, will be eliminated with the adjustment or replacement of the CCT, but we all knew that
      • ddragon63
        • Jan 2012
        • 1101
        • Ridgefield, WA
        +1 good point
        Don
        old:
        1989 kawi ex500
        1996 yzf-r6
        1999 yzf-r1
        2001 kawi zx-6r
        2000 Ducati 748
        2002 YZF-R1
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          • Fort Myers, Florida
          #34
          Good stuff
          No, thats good stuff to mention as the bikes turn backwards from most to help controll the shaft drive. Also, no matter how you change the CCT, how worn the chain is can effect the end result With tension on the chain from following the CCt adjustment, "IF" the chain has too much wear, it could slip off the crank But, what the hell, doner motors are everywhere
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            Originally posted by XS1100_OEM4ME
            No, thats good stuff to mention as the bikes turn backwards from most to help controll the shaft drive.)
            good to mention rotational direction.......last part not true. That direction of rotation in part was chosen by Yammy engineers as they considered torque directional which susposedly directed that torque internally directionally to the rear, not forward. That all may have been part of getting the most out of a streetable bike that all could ride, and still have the worlds quickest production scoot at that time.
            • JasonRedbeard
              • 109
              • Tuscaloosa, AL
              #36
              There may be another reason for the backwards rotation. The torque developed by an engine generates countertorque on the engine's mountings in the opposite direction that the crankshaft rotates. This means that when you crank the throttle and the bike starts to lift, the countertorque of the engine is trying to push the nose back DOWN, helping to keep your front wheel on the ground. Coincidence? Surely not.
              My Special is as old as I am.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                #37
                Well golly
                Well, someone keeps deleting my post, so I dont know if this will get through. Yamaha spun the motor backward to compensate for the drive shaft action, look it up if you like
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                  • 2071
                  OME, In the Clymers it simply states: "The cam chain should be adjusted every 3,000 miles (4,800km) or when it becomes noisy." I'm contemplating how to calculate when a CC is stretched to its max limit while using the ACCT. Should we go by mileage? Is there anyone, who wore out their cam chain, that can testify to what milage that is or will that be too broad of a spectrum as every engine is not treated equally? The stock CCT's length would give us an indication if removed with set screw in locked position and if fully extended and "it becomes noisy" one might want to remove and replace the cam chain with a new one. But how are we going to know that limit with the constant push of the ACCT? Would it make sense to keep the stock CCT in the tool box, fully extended and locked as sort of a dipstick for this measurement at certain milage intervals? ie...Remove ACCT every 10,000 miles and check depth with stock CCT, log measurement in maintaince record and reinstall ACCT repeat every 10,00 miles till full depth of stock "dipstick" is reached and then replace the cam chain. JAT
                  I agree
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    #39
                    Cool
                    I would say, if adding a auto CCT to your bike and when removing the OEM CCT and it is almost extended to its max, add a new timeing chain to the mod If it is only half way out or less, install the new CCT and ride, the next valve adjustment, replace the cain just for JIC, or at least the 2nd time you adjust the valves, but hey, it is your motor, might run forever with just gas and oil
                    I agree
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      #40
                      The oil that is the most slickery without screwing up my clutch.
                      • ddragon63
                        • Jan 2012
                        • 1101
                        • Ridgefield, WA
                        #41
                        I like that oil... where do you find it?
                        Don
                        old:
                        1989 kawi ex500
                        1996 yzf-r6
                        1999 yzf-r1
                        2001 kawi zx-6r
                        2000 Ducati 748
                        2002 YZF-R1
