Seat repair
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Seat repair
    My OEM seat on my XS1100SF has just started to get three very small cracks on the fake seam molded into it (only 33 years old, don't nothing last anymore) Has anyone used a repair kit / glue that worked to stop it before it tears
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    Hey OEM, I had a seat with a tear in it that was a decent size hole. About the size of a dime or so. I used a Vinyl repair kit made by Permatex to fix it. I have to say that unless I told you where the repair was you would have a hard time spotting it.
    • Danny Crawdad
      • May 2011
      • 239
      • Birmingham, Alabama
      OEM, how bad are the cracks? If they are superficial, I have had luck using Lexol Leather Conditioner. It moisturizes, and the leather "swells up" to fill in the cracks. Probably won't work for a seat that has more than a tiny bit of damage, but may be worth a shot! I use it every month since my bike is outside (but covered), and it keeps the leather soft and dark.
      I've also used leather repair kits like Leather Magic and the Permatex leather/vinyl kit with good results. As long as you don't have to do a bunch of color matching, they work well, but may be overkill for small spots (but then again, I've never used them on small spots so I don't know).
      XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
      Well, goodness. Look what we've got here.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Kit
        Was it the type where you apply the paste then heat it with a hobby iron?
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          Yes, it is "Permatex Pro Style Vinyl & Leather repair kit". You put the cloth backing under it, then add a repair adhesive/filler to the level f the surface, it shrinks a little when it dries. Then add the color compound and put the grain pattern paper over the color compound and apply the heat to the pattern paper. Worked really well for me on a seat.
          Here is a pic of the repair, admittedly it looks more obvious than I recalled in the bright light of the camera flash.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Nice
            Looks good! I know how the camera flash makes every little thing jump out at you I bet on the bike, you don't even see it My prob is. the spots are so small I dont know how I could get the backing under the hole without making it bigger or removeing the cover I might be able to push a small pice of backing in with a small screwdriver, then do the rest of the steps. I will give it a try, way less $$$$ then a recover job Dont have the funds right now too recover
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              The directions tell you that if the repair is that small, less than a 1/4", to skip the backing material.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                Cool
                Thanks DG and Danny, I will get some and give it a try Will "try" to reinforce from the inside also as I would like to nip it in the butt (that is where the holes are, where my butt sits)
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                  I've used regular RTV black to fix tears in seats. It holds up very well, you can even paint it gloss black when it's dry. Not that great for a restoration project though.
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    Cool
                    Does it glue togather enough to stop the tearing? I blame my big butt for pulling it apart, so it will need some hold
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      Yes it does a good job that lasts. If you got a super fat ass, maybe not. JK
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        No
                        No, as you can see, I am kinda of "average" build, at least that is how I describe myself on the dating sites
                        I think it was when I let my buddy's girlfriend take a ride on my bike that the rips started
                        Not going to do that again, my forks look a little bent too
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                          OK, seeing those images at this hour of the morning is just plain WRONG!!!
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            Working out
                            Well, as you can see from the pic of me, I have been working out (IE, the water bottle next to me) And my buddy likes a little "junk in the trunk" so dont know what you mean by that post
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • daveyg
                              • Feb 2009
                              • 411
                              • Boise, ID
                              Is that Nikki Menaj? I swear I saw that same wide can on one of her 'music' videos. Notice I put music in quotes cuz I think she would sound better at the bottom of a lake, but I can't even stand to see videos of her cuz I always feel like I need to zoom out but can't! As opposed to some of the other teenybopper 'musicians' that are actually quite enjoyable to watch as long as the mute button is handy for the times they quit shakin it and open their mouths...
                              BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
                              80 XS1100SG(cafe in progress *slowly)
