Paint Question
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Paint Question
    I'm repainting my tank using Acrylic Emamel. Due to my inexperiance I have some spots that need to be fixed.
    I know with lacquer you could just sand and repaint. What is the proceedure with Acrylic enamel. I chose this paint for its ability to withstand accidental contact with gasoline.
    If I chose to strip it down to the bare metal; what would be the best way.
    TIA
    Rick
    650SF
    XS1100SG Project bike
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Sand / Buff
    Sand the bad spots with 1500 grit till even, then sand everything with 2500 or 3000 grit till very smooth, wet sanding all grits with just a drop of dish soap in the warm water. Then hand rub with 3m or other prof. grade rubbing compounds, coruse then pollishing, wax after a months cure, looks like this when done
    TIA
    Rick
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • Barnfresh
      • Mar 2009
      • 160
      • Abilene, TX
      Rick:
      You want to use a hardener with the enamel that will make it dry faster, harder and make it gas proof. Your paint store should sell that along with reducer. Also a two part epoxy primer will work best over old paint, metal or body filler before you put your paint on. If you use a solid non-metalic color you can wet sand and buff it after it cures for a real shine like OME... You can't finish wet sand metalic enamel unless you put clear coat, but you don't need to clear coat single stage solid colors if you use hardener.
      Good luck and post pics!
      When the horse is dead, dismount.
      Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        True
        All good, but it sounded like you have already painted it If so, the steps I gave will work If you sprayed a metalic coat, I HOPE you did 2 coats of clear, otherwise, it will not hold up well, if only solid color coats, you can still fix with the sand and buff thing. Mine is jet black (solid color coat), but I still did 2 hardend clear coats for gloss and durability
        Originally posted by Barnfresh
        Rick:
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          Re-read
          OK, I am re-reading your post, did you paint and have some runs and bugs, or what Talking about stripping it down again and starting over, would love more info and pic's of what you are up againest would help on the right advice to move forward
          TIA
          Rick
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Also
            Also, it is getting COLD here in South West Florida
            So don't forget to check the temp to spray on the paint
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              I'm repainting my tank using Acrylic Emamel. Due to my inexperiance I have some spots that need to be fixed. - - -
              Hi Rick,
              if it's the primer showing through, fizz on another coat.
              If it's got runs in it, wet sand them off and fizz on another coat.
              But how bad is it really? Does it look OK from 3 feet away? For me, that'd be good enough.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                Pic's
                More info and pic's would be great! You can get a pro finish out of spray cans with little or no experance Help us help you, bugs, runs, all can be fixed
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • Rickrod3
                  • Jun 2009
                  • 721
                  Thanks to all for your eagerness to help. It is much appreciated.
                  I was pretty bummed.
                  Here now the photo.
                  The story that goes with the photo.
                  the chips in the top of the tank are from debris that got on the tank when painting. I make a make shift spray both in my garage with tarps and wet the floor to try to prevent this.
                  The day I shot it was in the low 50's F outside I had a small electric heater so I was fairly certian the temp was over 60 degrees F
                  I'm using a PPG enamel with hardener. The Toyota code which marches indigo Blue.
                  The side damage happened when I attempted to apply the striping some 30hrs. after shooting the paint.
                  Thanks again for your advise and recomendations.
                  Rick
                  650SF
                    At this point and with that damage, all you can do is wet sand the tank smooth and start over; trying to 'fix' it will be a waste of time. You don't have to sand all the paint off, but keep in mind that the thicker the paint is, the more prone to chipping it will be. You also don't want to use too fine of a sandpaper before spraying the color coat or the base won't have enough 'tooth' for the paint to grip. I'd suggest 320 grit, no finer than 400.
                    If you're planning on spraying catalyzed clear over the color coat and striping, you're supposed to do that within about 16 hours of applying the color coat or the clear won't chemically bond properly to the color. This is true of all catalyzed paint; too long between coats will cause issues. I'll also note that if the paint you're using has any metallic or pearl in it, you cannot color sand it or it will end up blotchy. You must apply clear over it to do that.
                      Steve, that color DOES have metallic in it......2002 Toyota Blue/Black Effect. and is correct match for 81Venturer. Had re-done my sidecovers some five years ago and posted the match code/color.
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Jat
                        Just a thought, but if trying to tape off the tank for striping lifted the color coat, you need to sand it all off as it didn't adhere properly to your primer coat. Most common reasons for that are spraying over primer without proper sanding of primer/ primer not completly dried and holding vapor/ wrong primer for the topcoat and / or topcoat reducer is not the right temp range for the temp you sprayed. Not trying to give bad news, but better to fix it right now then end up here again.
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                          Yeah, I thought so. That's why I try to stick to solid colors for my home paint jobs as they're waaay more forgiving... You can color-sand the dust/bugs out if it's not too bad.
                            • 8800
                            I would recommend a good 2 pt clear coat shot from airgun as a final protector against fuel. It is super easy to do and you get a nice glass finish with no worries when fueling up, JMHO. Costs about $35 for enough to do tank and sidecovers.
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              2k
                              You can also get 2K paint in spray cans now, here is one:
                              The SprayMax 3680061, 2K Urethane Glamour Clear Coat paint offers many benefits. Buy this 2K urethane aerosol clear coat spray can at R & E Paint Supply.
                              I used Alsa Killer 2K clear, works great but cost 40 bucks a spray can These othere brands are much less and prob just as good One can will cover tank and sidecovers fine
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
