James, when you apply the power makes a difference. Did you trigger the nitrous in low gear, then wide-open-throttle power-shift up to fifth? Or wait until you were in fifth, then hit the nitrous? Big difference in terms of shock loads to the clutch.
Full throttle shifting while drag racing puts tremendous stress on the driveline, particularly the clutch. Once that turbo spools up in first gear, the power is there, and the clutch will have to release/relock with each shift. Now, if IIRC, Barnett makes a 'extra plate' conversion for these for about 15% more friction area and that would help. But I'll throw this out there; having a clutch that slips a little may not be a bad thing. That can prevent other driveline breakage that may not be as easy to repair. And what tire you run will make a difference; if running the OEM shaft drive, that will limit how big a tire you can get under the bike and limited traction may provide the 'cushion' needed. I know that back when I was racing cars, 90% of my driveline breakage occurred when shifting.
I asked my brother-in-law about this; he ran (until 2 years ago) a turbo alcohol pro-mod bike that eventually went 6.90s at 190 mph (yep, big cojones!
). Before he gave up and sawed the OEM clutch/trans off the back of his motor for all-out race pieces, he was having breakage issues with them. His tip was to run an electronic wastegate, then install a switch on the shift or clutch lever that opened the gate when the lever was moved. This dumped power during shifts and let the OEM bits survive better.
Here's a old link (he's only running 7.4 @ 183 here!) to his bike... http://www.dragbike.com/dbnews/anmvi...sp?a=2353&z=14
