Need a clutch that will handle 150-200hp
  • ninety4point6
    • Oct 2011
    • 21
    • McPherson, Kansas
    I'm going to be building a draw through turbo system for my bike within the next couple months and I know the stock clutch won't handle it.
    I don't know to much about motorcycle clutches because I am coming from the car world.
    The bike will be mainly used for drag racing and quick blasts on the street.
    Thanks for the help.
    80 XS1100
    Draw through turbo build coming soon
    Barnett is the only one out there still making 'performance' clutch parts for these, so you should contact their tech dept and see what they say. But I doubt if it's rated to that HP level...
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      Might have to adapt one from a Vmax or 'Busa that makes that HP stock.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • James England
        • 3039
        • North of England
        I had nitrous oxide injection on an XS1100 and it was 190bhp on a rolling road. I found the clutch slipped when the nitrous kicked in but 10% stronger springs was all I did. I used the complete OEM clutch and just used the beefier springs. It never once slipped after that. I ran the nitrous for over a year on 'normal' road use (not racetrack) and never had any problems at all! While I was in there I replaced the release bearing too.
        • ninety4point6
          • Oct 2011
          • 21
          • McPherson, Kansas
          I'll check them out. Thanks.
          I'll look into what that entails. I know how to work a mill and a lathe so I might be able to adapt something like that.
          This is encouraging. Do you have a link to the springs that you used?
          80 XS1100
            • 9980
            Barnett clutch springs
            • ninety4point6
              • Oct 2011
              • 21
              • McPherson, Kansas
              Originally posted by BA80
              Thanks.
              I found some EBC springs that are 10% stiffer than stock.
              https://www.denniskirk.com/ebc/csk-c...prd/382009.sku
              Are the barnett springs better/stiffer?
              80 XS1100
              • James England
                • 3039
                • North of England
                They were just generic springs... EBC I think. Nothing special but 10% stiffer.
                • ninety4point6
                  • Oct 2011
                  • 21
                  • McPherson, Kansas
                  Cool, thanks.
                  How much were you spraying on your bike?
                  80 XS1100
                    Ebc springs work, but they measure out at just at or actually below factory spec for free length.
                    Barnett for just a couple bucks more are WAY better springs.
                    • petejw
                      • 2269
                      • sydney australia
                      you can also put washers behind the clutch springs
                      to stiffen the clutch up, itll give u a stiffer lever
                      but works well.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      1981 xs1100 RH (aus) (5N5)
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • ninety4point6
                        • Oct 2011
                        • 21
                        • McPherson, Kansas
                        Alright cool, thanks for the advice.
                        but works well.
                        I'll look into that. Thanks.
                        Stifff lever isn't a huge deal for me. All I really do is warm up the bike, go beat on it, and put it away. Usually only do quick rides to attempt to stay outta trouble.
                        80 XS1100
                          • 9980
                          Thanks.
                          I wouldn't use the EBCs if I were you. From what I've heard they don't have near the longevity of the Barnetts.
                          I have Barnetts in both bikes and no complaints.
                          • ninety4point6
                            • Oct 2011
                            • 21
                            • McPherson, Kansas
                            Alright sounds good. The Barnett springs it is then.
                            80 XS1100
                            • ninety4point6
                              • Oct 2011
                              • 21
                              • McPherson, Kansas
                              Any other opinions?
                              Thanks.
                              80 XS1100
