Brake Master Cyl Restoration
    The reservoir looked awful. It's all chalky looking. I went after it with one of those headlight restoration kits. It looks good now.
    It looked pretty nice after the 1000 grit followed by 2500 grit wet sanding. The kit has polish and a nice clearcoat to finish it off. It won't pass for new, but it no longer appears old and rotting.
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Front?
    I am guessing you are talking the front reservior?, Mine looked like crap, but cleaned it with soap and water and tooth brush (my woman never even tasted a difference on her brush) (removed from M/C of course) Cleaned the grove in the M/C houseing and re-installed with some sealer on the OEM O ring. Looks pritty good after and seals up nice. Got some pic's of your work? Love to see what you did
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
      Here you go... a before and after: http://www.xs11.com/forum/showthread...ight=reservoir
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        M/c
        Here is what mine looked like after useing my womans toothbrush Please don't tell her
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          Mine looks like Steve's before and after in the other thread.
          200 grit will remove the chalk in a hurry. The 2500 grit makes it real nice and the plastic polish is the finishing touch. I did not want to use enamel because of the brake fluid. If the coating in the headlight kit comes off, I might not notice it.
          The pieces that go on top of the reservoir (including the cover) are available from Mike's XS for the price of a new master cylinder. ($50)
          The O'ring that seals the bottom of the reservoir on mine is unserviceable. Does anyone here know where I can source one?
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Mikes
            I sall the one on mikes, didnt show the top, so dont know if it has the OEM decal, you can still get the OEM cap and dia. gasket if your metal is ok, for $45.00
            http://www.boats.net/parts/search/Ya...OSE/parts.html
            As to the O ring, off to ACE to match one up
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
