Micron fork brace
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    Micron fork brace
    Anyone with a unmodified micron fork brace on a Standard, please be kind enough to provide the number that's stamped on it.
    BAMN!
    '81 XS1100H "Brutus"
    Hey Nubian,
    Here's a recent thread with some photos, but no # showing, but James England is the one that has one, so hopefully he'll see this and post it for you!
    PS, good thing yours is a Standard, the thread states that the Micron won't fit on a special.
    PS, A little more research found this site started in 2006 selling Italian Imports FBs!
    This is for the Standard, they have a different one for Specials.
    NOTE: the number on the bottom is 185 for the mm's separating the fork tubes! Might be similar number on the Micron??
    And as stated, 37mm for fork tube diameter!
    • Nubian
      • Apr 2011
      • 467
      • The Big East
      Hey Nubian,
      Thanks, I'm not partial to micron but my budget is, trying to find a used one cheap.
      BAMN!
      • James England
        • 3039
        • North of England
        I'll go and have a look at mine and post back asap. My Micron is definitely unmodified... not sure if there are any numbers on it though...
        • James England
          • 3039
          • North of England
          There's no number stamped on mine! I've looked under the brace, on the collars etc and there is no sign whatsoever of a number. I did think that I'd never seen a number on it. Where would you say the number should be, by the way?
          • Giggity
            • Mar 2009
            • 113
            • Longmont, CO
            Are they made of platinum?
            http://www.ebay.com/itm/YAMAHA-350-L..._Parts&vxp=mtr
            1979 XS1100 Standard
            Putting it together........
            • Nubian
              • Apr 2011
              • 467
              • The Big East
              Well I wound up with two. Don't ask
              The first one I triple checked it's application since there was a model # on it (57G) and it was supposed to fit. It left a unexpected gap in the clamps, so I jumped on another that was specifically taken off a XS11, low and behold same model # and fit.
              This is what it looks like, I don't want to tighten more so I don't strip the threads, the gap is a little under 2mm, but I did notice that Mr. James England has got what seems like a much smaller gap on his.
              BAMN!
              • James England
                • 3039
                • North of England
                Yes, there is a smaller gap on mine but I really don't think a slightly larger gap will make any difference, if everything is tightened up and clamped tightly....
                • Shockman54
                  • Feb 2012
                  • 145
                  • Minneapolis, MINN.
                  is your fender bent at all? i had that problem with my last bike and it threw the whole handling of the bike off and i noticed that it changed the gap between the forks too.
                  1979 xs special, just finished the top end rebuild and then i still have lots of work.
                  progress thus far...
                  http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
                  "If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -Incubus
                  • Nubian
                    • Apr 2011
                    • 467
                    • The Big East
                    Very good point! As i've always noted in the past that there is a slight twist to the fender towards the front. Will look into it.
                    Thanks
                    BAMN!
                    • Nubian
                      • Apr 2011
                      • 467
                      • The Big East
                      Can anyone verify post # 2 from this link. This may be another possibility.
                      BAMN!
