Anyone with a unmodified micron fork brace on a Standard, please be kind enough to provide the number that's stamped on it.
Micron fork brace
Hey Nubian,
Here's a recent thread with some photos, but no # showing, but James England is the one that has one, so hopefully he'll see this and post it for you!
PS, good thing yours is a Standard, the thread states that the Micron won't fit on a special.
PS, A little more research found this site started in 2006 selling Italian Imports FBs!
This is for the Standard, they have a different one for Specials.
NOTE: the number on the bottom is 185 for the mm's separating the fork tubes! Might be similar number on the Micron??
And as stated, 37mm for fork tube diameter!T. C. Gresham
How nature points out the folly of men! -
Hey Nubian,
T.C.BAMN!
'81 XS1100H "Brutus"Comment
XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
There's no number stamped on mine! I've looked under the brace, on the collars etc and there is no sign whatsoever of a number. I did think that I'd never seen a number on it. Where would you say the number should be, by the way?
1979 XS1100 Standard
Putting it together........Comment
Well I wound up with two. Don't ask
The first one I triple checked it's application since there was a model # on it (57G) and it was supposed to fit. It left a unexpected gap in the clamps, so I jumped on another that was specifically taken off a XS11, low and behold same model # and fit.
This is what it looks like, I don't want to tighten more so I don't strip the threads, the gap is a little under 2mm, but I did notice that Mr. James England has got what seems like a much smaller gap on his.
BAMN!
Yes, there is a smaller gap on mine but I really don't think a slightly larger gap will make any difference, if everything is tightened up and clamped tightly....XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
is your fender bent at all? i had that problem with my last bike and it threw the whole handling of the bike off and i noticed that it changed the gap between the forks too.1979 xs special, just finished the top end rebuild and then i still have lots of work.
progress thus far...
http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
"If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -IncubusComment
ThanksBAMN!
Can anyone verify post # 2 from this link. This may be another possibility.
BAMN!
