any body use progressive springs?
  • 1fasttrucker
    • Jun 2011
    • 77
    • Mason, Michigan
    hay guys got my forks down and replacing seals and thinking about a set of progresive springs , looking for any pros and cons from some one allready been down that road! thanks ken
    Yep, I use them, they are a definite improvement over the stock units. They still might be a little on the soft side depending on your weight and riding style. Switching to a heavier fork oil (15W or 20W) will also help in conjunction with the progressive springs.
    • SFerinTEXAS
      • Jun 2006
      • 877
      I put them in my SF. It took a while to appreciate it but I def would not go back.
      79SF
      XJ11
      78E
        I'm a straight rate fan myself. With the correct spring, the ride is superior. I got mine custom wound from Traxxion Dynamics. I'm very happy.
        • SFerinTEXAS
          • Jun 2006
          • 877
          In my case watching the forks dive a little more at slower speeds seemed different.(at high speed I'm kinda busy). Then I realized that early soft bounce translated into a softer seat . So I'm sold.JMO
          79SF
          XJ11
          78E
            the rub for me was to get the proper laden sag, I run out of spring too quickly and the ride is very harsh.
              • 3193
              I have progressive's in my 79SF and I can absolutely say that it handles better than any of my other bikes. A bit to pricey to have them in all my bikes though. I would say yes indeed if they are in your budget range!!
