I'm making an ultrasonic cleaner and wondering if I could get some opinions on what to use in it. My main use is for my carbs but I'll likely clean my cylinder head as well. Would it be damaging to my seals or other rubber parts?
Spray nine to bath carbs
How
How do u make an ultrasonic cleaner?
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
i tried something similar sitting a bucket
on top of my bench grinder, it agitated the fluid,
but didnt really clean anything.
if u try it with the sander let us know how u go.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
Spa
I have an idea now for SWMBO's spa!
Dont want to pour rain on your parade, but that aint no utrasonic cleaner. Its a vibrating cleaner at best.. A typical Ultrasonic cleaner uses Ultrasound that oscilates at a frequency somewhere between 20 to 400khz, thats kilohertz. The sander will be lucky to achieve 100 hertz of mechanical vibration. Your washing machine will probably do a better job.1980 SG. (Sold - waiting on replacement)
Simple agitation will increase the chemical reaction speed and reduce the time needed for cleaning but to get ture ultra-sonic cleaning, the vibrations have to be very high, as in a cleaner used for jewelry or contacts which will break up very fine particles. When trying to clean things like carbs or other metalic parts, I'm not sure if ayone has ever compared the effectiveness of an ultrasonice cleaner to a much slower machine. I know a guy who cleans his pistols with an ultrasonic machine and swears by it. He's the pickiest old fart I know and he says the best thing is it gets into places you'll never get with conventional cleaning tools.Can't beat the smell of gas & oil
My question isn't regarding how well the sander and tub will work, but what cleaning solution to use. I know it's not near as good as an actual ultrasonic, but I'm not going to fork out that kind of money. I just don't want to ruin any seals or aluminum passageways.
Ultra sonic cleaning is a lot more complicated then that. If you were to take any of those parts that were cleaned in that tub and put them in a true ultra sonic cleaner you would soon see why. Ultra sonic cleaning involves creating microscopic bubbles in the right frequency range at higher sustained temperatures to work properly. Cleaners designed for use in ultra sonic cleaners are also different. They are made to allow the bubbles to be created in the right frequency range at the right size and last for the right amount of time to do the cleaning job. They contain wetting agents, cleaners, stabilizers etc.
What you wee in the video is intresting but not going to do nearly as good a job as a ultra sonic cleaner.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 Custom
Originally posted by YamaRule View PostMy question isn't regarding how well the sander and tub will work, but what cleaning solution to use. I know it's not near as good as an actual ultrasonic, but I'm not going to fork out that kind of money. I just don't want to ruin any seals or aluminum passageways.
1978 XS500E
1981 Suzuki GS1100
I would never circulate flammable fluids by using an aquarium pump. You would be risking fire or electrocution if the internals are not made for it.Skids (Sid Hansen)
