Spray nine to bath carbs
  • YamaRule
    • Apr 2010
    • 29
    • Nova Scotia
    I'm making an ultrasonic cleaner and wondering if I could get some opinions on what to use in it. My main use is for my carbs but I'll likely clean my cylinder head as well. Would it be damaging to my seals or other rubber parts?
  • jwhughes3
    • 2798
    • Home of the Alamo
    How
    How do u make an ultrasonic cleaner?
    John
    '81 XS1100H - "Enterprise"
    • YamaRule
      • Apr 2010
      • 29
      • Nova Scotia
      check this out, It's pretty simple, but cool!
      • SFerinTEXAS
        • Jun 2006
        • 877
        Before I looked at the vid I was pretty amused. I like thinking out side of the box. This certainly fits. I'm intrigued. Thanks. Jury's out on this one.
        79SF
        XJ11
        78E
        • SFerinTEXAS
          • Jun 2006
          • 877
          For the solution to use I still love the Yam Carb Cleaner that mixes with gas. It is flammable so watch out there. Maybe add an aquarium pump to the passageways . Love it.
          79SF
          XJ11
          78E
          • petejw
            • 2269
            • sydney australia
            i tried something similar sitting a bucket
            on top of my bench grinder, it agitated the fluid,
            but didnt really clean anything.
            if u try it with the sander let us know how u go.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • SFerinTEXAS
              • Jun 2006
              • 877
              Cant say I would go with a sander bunged to a plastic tub.It could be the start of an idea.
              79SF
              XJ11
              78E
              • jwhughes3
                • 2798
                • Home of the Alamo
                Spa
                I have an idea now for SWMBO's spa!
                John
                • b.walker5
                  • Feb 2009
                  • 1745
                  • Invercargill, New Zealand
                  Dont want to pour rain on your parade, but that aint no utrasonic cleaner. Its a vibrating cleaner at best.. A typical Ultrasonic cleaner uses Ultrasound that oscilates at a frequency somewhere between 20 to 400khz, thats kilohertz. The sander will be lucky to achieve 100 hertz of mechanical vibration. Your washing machine will probably do a better job.
                  • Lonerider62
                    • Nov 2011
                    • 187
                    • Gaylord, MI.
                    Simple agitation will increase the chemical reaction speed and reduce the time needed for cleaning but to get ture ultra-sonic cleaning, the vibrations have to be very high, as in a cleaner used for jewelry or contacts which will break up very fine particles. When trying to clean things like carbs or other metalic parts, I'm not sure if ayone has ever compared the effectiveness of an ultrasonice cleaner to a much slower machine. I know a guy who cleans his pistols with an ultrasonic machine and swears by it. He's the pickiest old fart I know and he says the best thing is it gets into places you'll never get with conventional cleaning tools.
                    Can't beat the smell of gas & oil
                    • YamaRule
                      • Apr 2010
                      • 29
                      • Nova Scotia
                      My question isn't regarding how well the sander and tub will work, but what cleaning solution to use. I know it's not near as good as an actual ultrasonic, but I'm not going to fork out that kind of money. I just don't want to ruin any seals or aluminum passageways.
                      • 79XS11F
                        • Jul 2006
                        • 3563
                        • Ottawa, Ont. Canada
                        Ultra sonic cleaning is a lot more complicated then that. If you were to take any of those parts that were cleaned in that tub and put them in a true ultra sonic cleaner you would soon see why. Ultra sonic cleaning involves creating microscopic bubbles in the right frequency range at higher sustained temperatures to work properly. Cleaners designed for use in ultra sonic cleaners are also different. They are made to allow the bubbles to be created in the right frequency range at the right size and last for the right amount of time to do the cleaning job. They contain wetting agents, cleaners, stabilizers etc.
                        What you wee in the video is intresting but not going to do nearly as good a job as a ultra sonic cleaner.
                        Rob
                        KEEP THE RUBBER SIDE DOWN
                        1978 XS1100E Modified
                        1978 XS500E
                        1979 XS1100F Restored
                        1981 Suzuki GS1100
                        1983 Suzuki GS750S Katana
                        1983 Honda CB900 Custom
                        • 79XS11F
                          • Jul 2006
                          • 3563
                          Ultra sonic cleaning will not alter the surfaces if the machine is used as intended with the right type cleaner for the parts in it at the right temperature for the right length of time. In a home made tub like that ... your on your own.
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                            • 7942
                            How about this:
                            Filled with this:
                            Heat ought to help, don't you think?
                              • 5062
                              I would never circulate flammable fluids by using an aquarium pump. You would be risking fire or electrocution if the internals are not made for it.
