sticky carb float
  • sticky carb float
    i'll be riding along all of sudden spit sputter gas pouring out of no.1 carb. stop tap it a few times and on my way. what do i need to look for when i take the bowl off? thanks.
    Just a wild guess here, but I'd guess you don't have inline filters or if you do that you have double walled automotive fuel line rather than the thin walled MC specific stuff or tygon. This will allow crud from the tank (if no inline filters) or pieces that come off the inside of the fuel line to work their way into the needle valve and keep it from closing. Tapping it with a hammer or something will force the foreign object back up the fuel line or force it on through so the needle valve can close.
      Didn't know that Mc fuel line was diff from auto
      81 XS1100H
        If it has happened more then once, I will bet the float is dropping to low and jamming in place. When you tap it, it comes loose till it drops to low again and sticks. I would check the stop that keeps it from droping down into the bowl, it only need to just open the needle then stop to work right (had this prob just a few month ago, pulled my hair out till I found the prob thanks to Phill) I would also make sure the float post dont have any burs on them, a quick smoothing with an emery bord will do, good luck with your bike, and change the oil if it flooded that bad, dont want to spin a bearing
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          Yep, automotive fuel line is double layer with a reinforcing layer to handle pressure as automotive fuel systems are pressurized. Bike systems (at least on older bikes) use single wall stuff that is not reinforced because it's not pressurized. The double wall stuff tends to flake pieces off when you push it onto the fittings and those pieces can get stuck in the needle valve and hold it open. This is why using automotive double wall type stuff is usually a BAD idea.
          Tygon is a good choice because it last long and won't flake off as well, but it can be a bit pricey.
            That would be almost impossible going down the road unless it was also sticking in the up position until the fuel level was getting low as under normal operating conditions unless there is a blockage the fuel level can only drop a VERY small amount. The jammed down issue usually happens either if you run out of gas or if the bike has sat for a while as the fuel level in the carb bowl has to drop significantly for it to happen. Happening going down the road is almost always foreign material getting stuck in the needle valve, either rust or pieces of fuel line.
              Moron
              Once again, I am a Moron Phill helped me with a float stuck problem and I thank him, I bow down to all the more intelagent posters Just trying to help, forgive my stupid thought
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
