i'll be riding along all of sudden spit sputter gas pouring out of no.1 carb. stop tap it a few times and on my way. what do i need to look for when i take the bowl off? thanks.
sticky carb float
Just a wild guess here, but I'd guess you don't have inline filters or if you do that you have double walled automotive fuel line rather than the thin walled MC specific stuff or tygon. This will allow crud from the tank (if no inline filters) or pieces that come off the inside of the fuel line to work their way into the needle valve and keep it from closing. Tapping it with a hammer or something will force the foreign object back up the fuel line or force it on through so the needle valve can close.Cy
Originally posted by cywelchjr View PostJust a wild guess here, but I'd guess you don't have inline filters or if you do that you have double walled automotive fuel line rather than the thin walled MC specific stuff or tygon. This will allow crud from the tank (if no inline filters) or pieces that come off the inside of the fuel line to work their way into the needle valve and keep it from closing. Tapping it with a hammer or something will force the foreign object back up the fuel line or force it on through so the needle valve can close.81 XS1100H
If it has happened more then once, I will bet the float is dropping to low and jamming in place. When you tap it, it comes loose till it drops to low again and sticks. I would check the stop that keeps it from droping down into the bowl, it only need to just open the needle then stop to work right (had this prob just a few month ago, pulled my hair out till I found the prob thanks to Phill) I would also make sure the float post dont have any burs on them, a quick smoothing with an emery bord will do, good luck with your bike, and change the oil if it flooded that bad, dont want to spin a bearing
Originally posted by bcknblkbird View Posti'll be riding along all of sudden spit sputter gas pouring out of no.1 carb. stop tap it a few times and on my way. what do i need to look for when i take the bowl off? thanks.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Originally posted by old_skool View PostDidn't know that Mc fuel line was diff from auto
Tygon is a good choice because it last long and won't flake off as well, but it can be a bit pricey.Cy
Originally posted by XS1100_OEM4ME View PostIf it has happened more then once, I will bet the float is dropping to low and jamming in place. When you tap it, it comes loose till it drops to low again and sticks. I would check the stop that keeps it from droping down into the bowl, it only need to just open the needle then stop to work right (had this prob just a few month ago, pulled my hair out till I found the prob thanks to Phill) I would also make sure the float post dont have any burs on them, a quick smoothing with an emery bord will do, good luck with your bike, and change the oil if it flooded that bad, dont want to spin a bearingCy
Moron
Once again, I am a MoronPhill helped me with a float stuck problem and I thank him, I bow down to all the more intelagent posters
Just trying to help, forgive my stupid thought
Originally posted by cywelchjr View PostThat would be almost impossible going down the road unless it was also sticking in the up position until the fuel level was getting low as under normal operating conditions unless there is a blockage the fuel level can only drop a VERY small amount. The jammed down issue usually happens either if you run out of gas or if the bike has sat for a while as the fuel level in the carb bowl has to drop significantly for it to happen. Happening going down the road is almost always foreign material getting stuck in the needle valve, either rust or pieces of fuel line.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
