auto cct install
  • Ebenezer
    • May 2011
    • 67
    • Hawley, MN
    auto cct install
    I just bought an auto cct off ebay. Can anyone give me any advice before I install it or is there a forum already? Couldn't find what I was looking for. Still a rookie and don't want to do any damage. Thanks
    Ryan
    1981 XS1100SH
    K&N filter
    Spade fuse block
    Barnett Springs
    Follow the cct removal and install just like it says in the manual. Nothing special. Just remember to depress the plunger and remove the spring before installing it and after bolting the housing on then put the spring and cap on.
    Also which auto cct did you get?
    • Ebenezer
      • May 2011
      • 67
      • Hawley, MN
      It's off an 2006 Venture Royal. I've been told it will work. It looks just like the other pics I have seen on here.
      Ryan
      1981 XS1100SH
      K&N filter
      Spade fuse block
      Barnett Springs
      • Lamric
        XStremely XSive(Deceased)
        • 410
        • Kenley, Surrey, England
        To remove your cam chain tensioner...
        1. Put the bike on center stand
        2. Remove the spark plugs (this will make it easier to turn the engine over by hand).
        3. Remove the screws securing the ignition cover (In front of your left foot).
        4. Slowly rotate the crankshaft clockwise several times with a wrench on the nut at the left-hand end of the crankshaft.
        Stop the rotation when the "C" mark on the timing plate aligns with the stationary pointer (if you go past this point carry on round until it comes up again, do not wind it back anti-clockwise)
        5. Unbolt tensioner
        Brian
        XS1100 LG "Mr T", SG "ICBM" & FJ1200
        Check out the XS Part Number Finder
        Be not stingy in what costs nothing as courtesy, counsel and countenance.
          • 8798
          IIRC, you need to use shorter bolts that hold the tensioner to the motor, the allen head ones. You may also have to temporarily bolt the tensioner to the motor to break loose the large front bolt.
          07 Triumph Tiger 1050
