rust!!!
  • Jelmo11
    • Nov 2011
    • 45
    • Sidney, Ohio
    rust!!!
    I have little rust on my fenders pipes and header what's the best way to remove it without causing more damage?
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Don't usu steelwool!
    Don't use steel wool! Dulls the chrome. The best way I have found is a good chrome cleaner and lots of elbow grease I use Turtle Wax chrome cleaner, i am sure there are many other fav's out there. Once you are done, "Wax often" or it comes right back. For realy hard to remove rust, you can use the superfine scothbright pads (availbule at autobody supply only) not the hardware store kind, with chrome cleaner, will dull some, but will look better then rust
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
      Chrome polish and elbow grease, and for the bad spots and/or the hard-to-get-areas, a small wire 'toothbrush' with polish. The brass ones work best as they don't leave scratches as much as the stainless steel ones...
      I've also discovered that if you have a buffing set-up, some tripoli compound on a sewn cotton buff will polish out rust and even scuff marks to a degree, just don't get heavy-handed.
        Wad up a piece of aluminum foil and go after it with that. You'll be pleasantly surprised.
        • GLoweVA
          • Jun 2011
          • 1957
          • Virginia Beach, VA.
          aluminum foil
          Alright Marty, you've peaked my interest now!
          How does a wadded up piece of tin foil get rust out?
          Wouldn't it scratch like steel wool? Albeit, a little softer of course.
          No Polish with that foil?
          Details PLEASE!
          80G (Green paint(PO idea))
          The Green Monster
          Got him in '04.
          bald tire & borrowing parts
          Scarlet
          Got her in '11
          Ready for the twisties!
          81H (previously CPMaynard's)
          Hugo
          Cold weather ride
            I have used the wadded up aluminum foil with chrome polish and it does work really nice.
              I use it with nothing. Water will lube it enough. It won't scratch like steel wool.
              • LuckyEddie
                • 166
                • Middleville, Michigan
                +1 for foil
                Aluminum foil with water works like majic for taking rust off chrome. It will not restore chrome that is no longer there due to heavy rust though. I think that it works because the aluminum is not as hard as chromium, but harder than the rust, so no scratches.
                LuckyEddie
                1980 XS1100LG Midnight special
                1982 XV750J Virago
                1976 GL1000
                1978 GL1000 Supercharged
                1981 XV920RH (chain drive)
                • petejw
                  • 2269
                  • sydney australia
                  wasnt it mythbusters that did a show
                  with the foil and coke a cola to polish up chrome.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  1981 xs1100 RH (aus) (5N5)
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                    foil method
                    Chrome Polishing, Mythbusters Style: OK, I know that the Mythbusters didn't invent this idea, but that's where I heard about it.
                    Explained:
                    • jwhughes3
                      • 2798
                      • Home of the Alamo
                      Yes
                      And as a side note while searching for the Mythbusters episode I ran across a neat how to on making a fire with a coke can and chocolate bar.
                      Damn, now I have to try it.
                      John
                      '81 XS1100H - "Enterprise"
                        Can you connect us to the MYTHBUSTERS episode?
                        • Jelmo11
                          • Nov 2011
                          • 45
                          • Sidney, Ohio
                          Coke and foil holy begeezem it worked fantastic thought it was just a myth but wow its great stuff thanks all
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            Scratched
                            Looks pretty scratched in the after photos to me
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • jwhughes3
                              • 2798
                              • Home of the Alamo
                              No link
                              Directly to episode, but its Episode 5 season 2003.
                              John
