Oil drain plug won't fully tighten
  • Danny Crawdad
    • May 2011
    • 239
    • Birmingham, Alabama
    Originally posted by Axel
    Sidenote: This plug seems longer than the one pictured above . It has a good length of O/S thread and an additional tapered cutting area with the relief slots .
    YES! I forgot to mention this, the plug I received was also much longer than the original, and from looking at the used oil pan I have nearby, probably engages the deeper threads in the pan. I've taken mine out already twice to do a flush and an oil change, and it screws back in and snugs up without a problem. I have the oil pan on hand to replace if necessary, but if it keeps holding up, I don't think it will be.
    And no more drip directly onto my exhaust anymore .
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      Finally
      That Napa site is a tough nut to crack .
      BALKAMP Single Oversize Oil Drain Plug M14 x 1.5mm
      7041362
      Line Code - BKP
      Requires a 18mm wrench
      Not a very good pic but :
      XJ1100K
      Avon rubber
      MikesXS black coils
      Iridium plugs w/ 1k caps
      MikesXS front master
      Loud Horns (Stebel/Fiamm)
      Progressive fork springs
      CIBIE headlight reflector
      YICS Eliminator
      • Danny Crawdad
        • May 2011
        • 239
        That's the one. How my multiple searches for "oversize drain plug" and "Drain plug" and "oversize" and "m14 x 1.5" didn't turn it up I will never be able to explain :P.
        • petejw
          • 2269
          • sydney australia
          #34
          jat, next time you need to tap a bolt
          throw sum grease on the threads, itll help catch
          most of the shavings.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            #35
            Napa
            I had to look it up on this site and bring the number back to the Napa site :
            On this site they refer to the piggyback 7041909 as an oversize plug so it may thread into the hole our 7041362 has cut but this is only speculation .
            Ahh grease - doh ! My brain has been on vacation this month . I should at least remember to check here before performing repairs .
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
            • LoHo
              • Sep 2002
              • 1342
              • Fresno, CA
              #36
              You may be all done fooling with this by now, but when I stripped mine, I bought a slightly oversized brass fitting that had a threaded interior, tapped the stripped oil pan aluminium hole to fit and locktited it in, and a brass plug to fit the inner threads of the brass insert, so now I'm brass to brass rather than steel to aluminium.
              As I was doing this on the bike, I greased up a chunk of paper towel and stuffed it in the hole to catch the metal shards, pulled it out with foreceps, and then rinsed the pan with the soon-to-be-replaced oil to make sure I got them all.
              • Axel
                • May 2007
                • 869
                • Renfrew,Ontario
                #37
                new and improved ?
                Seems I ordered an updated? version :
                No built-in washer ,4 cutting slots , small-ass inner plug with 11mm cap.
                Large hex size is still 24mm .
                Hmm.
                XJ1100K
                Avon rubber
                MikesXS black coils
                YICS Eliminator
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  #38
                  more on this
                  I just got my replacement oil pan in the mail . My old OEM drain plug is about 15mm from cap to tip ( thread portion) and doesnt reach all of the threads available in my XJ pan . There is a second set of threads in the pan after a small oil drain section . There is approx. 5mm more to take advantage of .
                  Thread area:
                  Plug threaded in finger tight(no washer):
                  OEM Plug:
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  YICS Eliminator
                  • DAVINCI
                    • Jan 2011
                    • 1048
                    • Cedar Mountain, NC
                    #39
                    Good pics
                    And as you can see from them, using one of those semi-permanent plugs will block the drain slot, so you'll never again fully drain the pan and the flotsam and jetsam will build up.
                    Just a thought.
                    • Axel
                      • May 2007
                      • 869
                      • Renfrew,Ontario
                      #40
                      too much time on my hands
                      XJ1100K
                      Avon rubber
                      MikesXS black coils
                      YICS Eliminator
                      • Danny Crawdad
                        • May 2011
                        • 239
                        #41
                        Nice! What did you use?
                        • Axel
                          • May 2007
                          • 869
                          • Renfrew,Ontario
                          #42
                          thanks
                          brass wire wheels on the Dremel, series of sandpaper (150,220,320,600,1000,1500,2000)
                          and a drill mounted buffing wheel with some white compound .
                          XJ1100K
                          Avon rubber
                          MikesXS black coils
                          YICS Eliminator
                          • Axel
                            • May 2007
                            • 869
                            • Renfrew,Ontario
                            #43
                            so far
                            Happy Spring ! The 1st O/S plug leaked constantly so this year I installed the plug with the plug in it . Red loctite and it seems good so far . I didn't dare torque it to the 31 ft/lbs as it seemed not to want to get any tighter than about 21 ft/lbs . So I'm glad I have the pan now that I've heard the engine can stay in to change it . It will be part of the exhaust job somewhere down the line.
                            XJ1100K
                            Avon rubber
                            MikesXS black coils
                            YICS Eliminator
