Oil drain plug won't fully tighten
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    yup
    I just stripped mine at the last oil change of the season - figures .
    Any chance of a NAPA part number for that replacement ?
    Might improve my chances at the local one .
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
      A search on their site revealed this one:
      Part Number: BK 7041909
      Product Line: Balkamp
      Attributes:
      Contents : Plug, Gasket
      Oil Drain Plug Hex Size : 24 mm
      Oil Drain Plug Material : Fiber
      Oil Drain Plug Thread Size : M14-1.5
      Features and Benefits:
      Piggy Back Plug Replaces Lost Or Damaged Drain Plug & Ensures Snug Fit For Leak Free Operation
      Warranty:
      12 Months or 12,000 Miles Whichever Occurs First
      Important Information:
      14mm X 1.50 Thread Size
      Single Oversized Piggy Back
      • Danny Crawdad
        • May 2011
        • 239
        • Birmingham, Alabama
        That's not the one I got, but it's the one I wish I'd gotten . Aside from the captive bolt-in-a-bolt, mine was the same otherwise -- tapered, self-tapping (slotted) plug. The only difficulties I had were getting it started -- make sure it's straight, and just keep slowly turning it until it bites. Then slowly work it in. I kept it oiled very well with motor oil as I was putting it in, and pulled it out and cleaned the shavings out of the tip a few times, then used an oil-soaked rag to wipe the inside of the hole once it was finished cutting, and flushed the plug well with oil to get the shavings off.
        Worked very well on mine. No problems, no leaks. Just make sure you start it straight! Compare the way the old drain plug seats in the hole and make sure the new one doesn't try to wobble as it cuts the first thread. I used an extension and socket wrench, and put pressure on the head of the wrench, and turned the extension by hand to start it. Once it bites and begins making threads it's no issue.
        If you end up using the captive plug (as above), I would take TC's suggestion and throw some red loctite on there.
        Even if it doesn't go as well as it should and the pan gets messed up, Andreas Weiss has used oil pans for cheap, so all isn't lost. Less than $30 shipped cheap.
        XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
        Well, goodness. Look what we've got here.
        • Danny Crawdad
          • May 2011
          • 239
          Couldn't find the box for the one I got, and can't find it on the site, I should be able to get the part no. for the one I got tomorrow, though, if you just want a one-piece plug.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            • Fort Myers, Florida
            Danny
            Hi Danny, I think you did fine, you were carful to remove the shavings and I like the fact the the "one-in-one" bolt will let all the oil drain out when draining the pan (most of the crap is in the last few drops that come from the pan) Don't worry, be happy
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
            • Axel
              • May 2007
              • 869
              • Renfrew,Ontario
              Right on
              Thanks T.C. Seems like a good idea to not keep wearing away the soft metal .
              I'm wondering if I would get much mileage out of a longer plug to reach those extra threads Phil mentioned . Ahh decisions ...
              XJ1100K
              Avon rubber
              MikesXS black coils
              YICS Eliminator
                • 8962
                Axel, it's going to be hard to find an oil drain bolt that long, I used a regular metric bolt with a nylon washer. It had a larger head on it (22mm?) which made it more difficult to remove with my 4-1 headers, YMMV. I have since replaced the oil pan.
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  ok
                  Thanks Phil . I will take that into consideration . I found the shift detent bolt 3Phase mentioned on eBay . It is about the price of another pan ( $35 delivered) .
                  I'm off to Napa today to see whats up . I will drop the oil again and see whats available to remedy the situation . The bike is in storage so I am limited to what operations I can perform . Thanks again everybody for your posts .
                  I was quite frustrated in the beginning but now I see it is just another repair .
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  YICS Eliminator
                  • DAVINCI
                    • Jan 2011
                    • 1048
                    • Cedar Mountain, NC
                    Want a longer 'bolt'? Try an old spark plug. BTW, they also fit the rear pumpkin and the middle drive.
                    • Axel
                      • May 2007
                      • 869
                      • Renfrew,Ontario
                      wow
                      Now that is good to know !
                      I went to Napa and was denied the oversize type of plug so went on with a new magnetic normal size plug that had a thread length of 12mm .
                      Turns out my plug on my XJ also had a thread length of 12mm . So no joy there .
                      I returned to Napa and to my surprise they had found the oversize plug of the type Danny used . I ordered the piggyback type and went back to the bike again .
                      Just like Danny said this cuts deeper threads so there is metal filings involved . I used a magnet on a stick to probe around inside the pan to attract any offensive matter . I cut and then removed the plug repeatedly to clean it of filings .
                      In the end it worked like a charm .
                      Sidenote: This plug seems longer than the one pictured above . It has a good length of O/S thread and an additional tapered cutting area with the relief slots .
                      I'm wondering( I know) if I should install the piggyback as it seems so much shorter and there is no mention if it is an oversize plug . It says replacement if lost or damaged . I would imagine that now I have used the oversize plug that the piggyback might be kinda loose even with red loctite . T.C. ?
                      It was a good day , all in all .
                      XJ1100K
                      Avon rubber
                      MikesXS black coils
                      YICS Eliminator
                      • DAVINCI
                        • Jan 2011
                        • 1048
                        A magnet isn't much good with non-ferrous metals
                        • Axel
                          • May 2007
                          • 869
                          • Renfrew,Ontario
                          Damn
                          Oh crap - I better drop that oil out again before I start the engine.
                          XJ1100K
                          Avon rubber
                          MikesXS black coils
                          YICS Eliminator
                            $35?!
                            I think I have one lurking in a roached engine case somewhere. If I can make peace with the spiders long enough to dig it out of the shed you can have it.
                            • Axel
                              • May 2007
                              • 869
                              • Renfrew,Ontario
                              Appreciation
                              Thanks but I think that bird has flown
                              XJ1100K
                              Avon rubber
                              MikesXS black coils
                              YICS Eliminator
                                Saw that after I posted but it was too late to un-post!
