yup
I just stripped mine at the last oil change of the season - figures .
Any chance of a NAPA part number for that replacement ?
Might improve my chances at the local one .
. Aside from the captive bolt-in-a-bolt, mine was the same otherwise -- tapered, self-tapping (slotted) plug. The only difficulties I had were getting it started -- make sure it's straight, and just keep slowly turning it until it bites. Then slowly work it in. I kept it oiled very well with motor oil as I was putting it in, and pulled it out and cleaned the shavings out of the tip a few times, then used an oil-soaked rag to wipe the inside of the hole once it was finished cutting, and flushed the plug well with oil to get the shavings off.
