fuel filters - vacuum lines?
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    I am considering adding two inline fuel filters between the bowls and both fuel feeds (Prime / ON, is this a good idea The Oxy vacuum line is hooked to one of the intake manifolds and the ing. advance is hooked to the one carb. body with a vac tube, correct?
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • 8962
    Yes, it is a good idea to run fuel filters, not much room though with the octy in there so run some small ones. Careful not to pinch fuel lines when the tank is in position. Octy to carb boot manifold vacuum, vac advance to ported vacuum on the #2 carb body.
      I run two Visu Filters between the carb bodies and with the "octy" valve. Not too much of a challenge to fit them while replacing my fuel lines.
      I bought mine at my local bike shop.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        The dreaded flood is back!!!
        Well, got them all done with new XV920 needle kits and new in-line filters, hooked everything back up, and presto GAS POORING OUT THE CARBS AGAIN. Pulled the vent lines, GAS STILL POORING OUT OF THE CARBS AGAIN. Included is a photo of my work (please note these were 32 years old and had lived outside for years when I started on them, and looked nothing like they do now) I am as precise with the insides as I am with the outsides, set all floats with a mic. slide rule and set float max range to just past open on new needles and nothing is binding
        Here is what they look like if this link comes through:
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          • 8962
          Did you tap on all 4 float bowls on initial filling? Does the leak stop when tapping on the float bowls? Those 2 hoses you have on the upper T's are running to the airbox or remaining open, correct?
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Yes
            Yes, didn't help. It looks like the leak is only on the right two (wich could mean only one is leaking as the two are linked0 Fuel comes out of the vent hose when I removed the carbs and bench tested tonight, going to pull the bowls and bench test one side at a time pushing the floats up with my fingers
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              • 8962
              Yep, it sounds like a float is still hanging up or possibly the float valve washer not sealing.
              • mikubuilder
                • Jul 2011
                • 548
                • Westland, Mich.
                nice work on those carbs...how long did that take?
                Nick
                1982 Virago 750 (it's alive!)
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  Carbs
                  Thanks, about an hour polishing, 1/2 hour cleaning + overnight soak of hard parts, 1 hour rebuilding and setting floats and assembly
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
