Ordered the gasket set and guess what, the middle drive housing cap gasket isn't part of the set. Seemed to be made of a rubbery type of material not fiber like the rest. What are we using to make these now gentlemen?
Gasket set
Gasket set
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
I would use the old one with a little 3 Bond. 3 Bond itself would be sufficient I believe.Greg
Painting
Unfortunately I had to do some painting in that area so the old one came off with a scrapper. It's so close to the bearing that I'm reluctant to use a product similar to what I used to attach the final drive. Afraid it might squirt into the bearings. I'll head to an auto supply place monday and have a look at what they have. Crap!! It's always the little things that cause the biggest problems.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
You can make your own gasket, but according to page 24, Chapter 6, of the manual, <http://www.yamaha-triples.org/library/misc/shaftdrivemanual/ShaftDriveManual.pdf>, it has to be .012 in thick when new.
NAPA sells gasket material, paper hole punches are the right size for the holes, and an Exacto knife will cut the stuff easily. Take a mike with you to the NAPA store, as you never can trust a parts man to know what, exactly, he is selling. I have used cereal boxes for material in an emergency, and not had trouble. Coat the cardboard
all over with Gasgachinch or equal, and they work fine.
YMMV CZComment
☮Comment
Happy
Cool Phil you made my daymack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
I see Phil has the gasket for you. If you end up making one, or need to for another part, the UK XS11 site has a complete gasket library. It gives you a to scale diagram of the gasket you can print out on your printer and use it to make the gasket. VERY nice to have.Life is what happens while your planning everything else!
78 XS750Comment
And here's a link to the XS1100UK Gasket Library
Brian
Be not stingy in what costs nothing as courtesy, counsel and countenance.Comment
Looks like there are still a few new ones in existence.
