Gasket set
  • mack
    • 2411
    • Ontario, Canada
    Gasket set
    Ordered the gasket set and guess what, the middle drive housing cap gasket isn't part of the set. Seemed to be made of a rubbery type of material not fiber like the rest. What are we using to make these now gentlemen?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 9981
    I would use the old one with a little 3 Bond. 3 Bond itself would be sufficient I believe.
    • mack
      • 2411
      • Ontario, Canada
      Painting
      Unfortunately I had to do some painting in that area so the old one came off with a scrapper. It's so close to the bearing that I'm reluctant to use a product similar to what I used to attach the final drive. Afraid it might squirt into the bearings. I'll head to an auto supply place monday and have a look at what they have. Crap!! It's always the little things that cause the biggest problems.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        You can make your own gasket, but according to page 24, Chapter 6, of the manual, <http://www.yamaha-triples.org/library/misc/shaftdrivemanual/ShaftDriveManual.pdf>, it has to be .012 in thick when new.
        NAPA sells gasket material, paper hole punches are the right size for the holes, and an Exacto knife will cut the stuff easily. Take a mike with you to the NAPA store, as you never can trust a parts man to know what, exactly, he is selling. I have used cereal boxes for material in an emergency, and not had trouble. Coat the cardboard
        all over with Gasgachinch or equal, and they work fine.
        YMMV CZ
          • 8962
          http://www.nwvintagecycleparts.com/s...Y0-00&st=spart
          • mack
            • 2411
            • Ontario, Canada
            Happy
            Cool Phil you made my day
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
              I see Phil has the gasket for you. If you end up making one, or need to for another part, the UK XS11 site has a complete gasket library. It gives you a to scale diagram of the gasket you can print out on your printer and use it to make the gasket. VERY nice to have.
                • 8962
                No problem Mack, glad to help. Looks like there are still a few new ones in existence.
                • Lamric
                  XStremely XSive(Deceased)
                  • 410
                  • Kenley, Surrey, England
                  Originally posted by DGXSER
                  ...the UK XS11 site has a complete gasket library. It gives you a to scale diagram of the gasket you can print out on your printer and use it to make the gasket. VERY nice to have.
                  And here's a link to the XS1100UK Gasket Library
                  Brian
