Thanks to ELDR for researching how the stock flasher works which gave me the background needed to figure this out. If you
are running LED turn signals you might consider his flasher module which does the same thing but is limited to LED lights
only.
This mod is really quite simple. It requires cutting two wires close to the flasher connector and wiring in two relays.
First, get together the parts and tools you will need to do this. Here is the list of parts and tools that I used.
Tools:
Soldering Iron
Needle Nose Pliers
DVOM for Troubleshooting
Parts:
Heat Shrink Tubing
Zip ties (cable ties)
Mounting bases for cable ties
10 Amp SPDT 12v 30 MA Relay Philmore part # BG-112
2 Amp DPDT 1v 15 MA sensitive coil Relay NTE part # R40-11D2-12
6" to 12" of 14 gauge stranded automotive wire
Now, your going to start by cutting two wires close to the flasher plug, one you can cut as close as you want, the other
you need to leave enough wire to strip, tin and solder another wire to.
Cut the Yellow/Green wire, you can cut this as close to the connector as you want, as it will NOT get connected back to the
connector, this is drive the 2 amp relay which will in turn drive the 10 amp relay. This is done because the 2 amp relay
cannot handle normal bulbs, but the auto cancel unit can't drive the 10 amp relay.
Next cut the Brown wire. Make sure to cut this far enough from the connector that you can connect another wire to both ends
to extend the wire, you will be inserting the 10 amp relay in here to enable it to turn off the turn signals when the auto
cancel unit tells it to.
Determine where you want to locate the relays, I located mine just below where the flasher unit lives, and since they are
really small and light I let them just hang by the wires, but you can fasten them in place with double sided tape or with
zip ties if you wish.
For the 2 amp relay find the switch side of the relay and connect the previous relay wire to one side switched setup for
normally open operation, connect the other side to either the brown wire of the turn signal relay or as I did connect it to
the downstream side of the turn signals fuse (I added it to the crimp connector). Connect the coil, one side to the
Green/Yellow wire from the bikes harness, and the other side to a good ground, I used the same ground screw as I used for
the other relay.
Now, slide some heat shrink over one of the wires for the coil side of the 10 amp relay, but keep it back a ways so it
doesn't shrink when you solder the wire. Solder the wire to the output of the 2 amp relay. Push the shrink tubing up and
strink it into place. Connect the other wire to a good ground, I used the ground screw of the accessory connector.
Find the leads for the switch side of the 10 amp relay, and find the normally closed side. The DVOM on ohms can be your
friend here. Solder a short piece of wire to each side of the normally closed switch. Put shrink tubing over it and shrink
it with a heat source (I use the soldering iron). Do the same with the coil side of the relay, keep track of which ones are
which.
Now, the last electrical part, solder the remaining two wires to the two brown wires, making sure to cover the solder
joints with heat shrink. Fasten everything into place, I used the cable tie mounting bases and cable ties to mount things,
and your ready to test.
If you did everything right, you can turn on the turn signals before starting the bike, and then start the bike. The turn
signals should not come on when the key is turned on. If they do, recheck your wiring job and parts, if everything is
working properly the system comes up with the flasher inhibited.
If this test passes, take it out for a test run, the auto cancel should work just like you have the stock flasher in place
with the correct normal bulbs, whether you have the normal bulbs or LED bulbs.
The Schematic:
only.
Tools:
Soldering Iron
Needle Nose Pliers
Parts:
Heat Shrink Tubing
the other relay.
which.
The Schematic:
) as well as solder and heat shrink. But the two relays ran around $10 so figure under $20 for parts if you need heat shrink and solder, assuming you have a soldering iron already. It took me about 2 months to get the design finalized to what I ended up with, as I tried several other combination before I ended up with the final design, so I actually spent a bit more than what I quoted here, but that was because I was prototyping the design as I went, and several rounds of different ways of doing it went through the mill, some of which ALMOST worked, but only the last of which really worked right, and now I've got a reed switch in my speedometer that's not liking cold very much, so it only works about 40-60% of the time when it's cold out (which is pretty much all the time right now), so I've got to source a new one of those (not putting a used one in there, going to put a brand new one in there that will be good for another 90,000+ miles)
