Hi techies, Driving from BC Canada to "Beloved" festival in Tidewater OR, I lost all ignition all of a sudden, stonedead. Checked fuses OK, checked to see if voltage arrived on tci box, Ok, ignition lights remain on.Looks like tci box to me, otherwise if it was coils it would fire on 2 cyl, right? It is my xs1100 standart. I tried to open t I box in despair and broke it . I am so f&$led. Any opinions on my diagnostics? Any tci boxes available? Any input at all? Discouraged, hoping for some input.
Help!! Broke down south of Lincoln, OR
80 1100SG with 79 engine
79 1100F being restored
78 xs650 runabout (mpg, eh?)
Irreverence is the champion of liberty and its only sure defenseTags: None -
Did you check your pick up coils? Push and pull a little bit on the wires to see if you can get it started.
OzzFour wheels move your body, two wheels move your soul.
1980 XS 1100SG
Dyna 3 Ohm Hi Output Coils
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCT -
OK, it was probably something simple but now that you have busted your TCI you are screwed for a quick fix.
So how far did you get?
Park the bike someplace reasonably safe. Absent someone local with a spare TCI:-
If more than 1/2 way, hitch to festival and get sorted later.
If less than 1/2 way, abandon festival, hitch home and borrow a pickup truck.Last edited by fredintoon; 08-12-2011, 04:42 PM.Fred Hill, S'toon
"The Flying Pumpkin"Comment
SWMBO's 'H died like this a while back when we were on our way home from Vernon. It turned out to be a multiple failure of the pick-up coil wires, but not inside the engine case. It was back around the driver's footpeg where the wire bundle passes along the engine before it routes its way up to a plug connector behind the fuse box. I pulled the wire from a clip style retainer, and found a melted, semi-charred mass of copper and plastic. On the roadsire, I was able to get enough slack to cut the fused mess completely out, bare and twist the appropriate wires together, give each connection a bit of black tape, and ride home.
Hope yours is as simple as ours was.Ken TalbotComment
I'm not sure how to contact him, but I think that Geezer is in that area somewhere. It's a little bit further than I am able to provide physical assistance to unfortunately or I would come out to assist.Cy
Poprock is close too. Got friends in Newport south of Lincoln City. Somebody call me if I can help. No parts available though. I have Geezer's #.
503-842-00771980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
Well, he hasn't updated since his first post so I would guess it's handled.
Would be nice to know though.Greg
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.โ
โ Albert Einstein
The list changes.Comment
Curious
As a shot in the dark, being a 79, and on the west coast (wet), if his ballast resister crapped out, it would die all of a sudden wouldn't it?mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
However his larger problem now is the damaged TCI. Not quite so easy to deal with on the side of the road...1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
Yo, brothers
I just got the tci unit via courier from super Dave in langeley bc. I went to the festival after I ordered the part , hence I was out of wifi range . Thank you all for your input, in about one hour I will know if the tci will fix it. If not iwill us your other leads. "Beloved" festival was simply heavenly, very sweet energy, a bit of a chickflick of a festival . So I feel well nurtured now by you and all the kind hippie chicks. You all rock . More in a few hours80 1100SG with 79 engine
Irreverence is the champion of liberty and its only sure defenseComment
Up 'n runnin...
Yo, good people. It was the tci . Plugged in the 'new' one, and she is purrin like the proverbial pussy. Thank you all again, it is good to be connected to folks who care .. PS: I'm sort of glad my destruction of the old tci was not destroying a good part. Makes me feel slightly less goofy. Rockin on...
Glad you found the problem. Have a safe ride home.Four wheels move your body, two wheels move your soul.
1980 XS 1100SG
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCTComment
That's good news. Woulda waved when you went by Tillamook if I'd known when. Have a great trip home. The weather is sweet right now. Say "Hey" when you head south again.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
