Help!! Broke down south of Lincoln, OR
  • jurgenkoppen
    • Jul 2007
    • 97
    • Powell River, BC Canada
    Hi techies, Driving from BC Canada to "Beloved" festival in Tidewater OR, I lost all ignition all of a sudden, stonedead. Checked fuses OK, checked to see if voltage arrived on tci box, Ok, ignition lights remain on.Looks like tci box to me, otherwise if it was coils it would fire on 2 cyl, right? It is my xs1100 standart. I tried to open t I box in despair and broke it . I am so f&$led. Any opinions on my diagnostics? Any tci boxes available? Any input at all? Discouraged, hoping for some input.
    80 1100SG with 79 engine
    79 1100F being restored
    78 xs650 runabout (mpg, eh?)
    Irreverence is the champion of liberty and its only sure defense
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    Did you check your pick up coils? Push and pull a little bit on the wires to see if you can get it started.
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
      Hi Jurgen,
      OK, it was probably something simple but now that you have busted your TCI you are screwed for a quick fix.
      So how far did you get?
      Park the bike someplace reasonably safe. Absent someone local with a spare TCI:-
      If more than 1/2 way, hitch to festival and get sorted later.
      If less than 1/2 way, abandon festival, hitch home and borrow a pickup truck.
        SWMBO's 'H died like this a while back when we were on our way home from Vernon. It turned out to be a multiple failure of the pick-up coil wires, but not inside the engine case. It was back around the driver's footpeg where the wire bundle passes along the engine before it routes its way up to a plug connector behind the fuse box. I pulled the wire from a clip style retainer, and found a melted, semi-charred mass of copper and plastic. On the roadsire, I was able to get enough slack to cut the fused mess completely out, bare and twist the appropriate wires together, give each connection a bit of black tape, and ride home.
        Hope yours is as simple as ours was.
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          I'm not sure how to contact him, but I think that Geezer is in that area somewhere. It's a little bit further than I am able to provide physical assistance to unfortunately or I would come out to assist.
          • Poprock
            • Apr 2005
            • 594
            • Oregon Coast
            Poprock is close too. Got friends in Newport south of Lincoln City. Somebody call me if I can help. No parts available though. I have Geezer's #.
            503-842-0077
              Well, he hasn't updated since his first post so I would guess it's handled.
              Would be nice to know though.
              • mack
                • 2411
                • Ontario, Canada
                Curious
                As a shot in the dark, being a 79, and on the west coast (wet), if his ballast resister crapped out, it would die all of a sudden wouldn't it?
                mack
                79 XS 1100 SF Special
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                https://youtu.be/wB5Jfbp6SUc
                https://youtu.be/RaI3WYHSuWA
                Frankford, Ont, Canada
                613-398-6186
                • b.walker5
                  • Feb 2009
                  • 1745
                  • Invercargill, New Zealand
                  Possibly, same thing happened to me years ago. Turned out to be a shagged spade connector on the resistor. (i bridged it out with a strip connector on the side of the road (in the rain) to get me where i was going and it's still bridged out to this day, on standard coils)
                  However his larger problem now is the damaged TCI. Not quite so easy to deal with on the side of the road...
                  • jurgenkoppen
                    • Jul 2007
                    • 97
                    Yo, brothers
                    I just got the tci unit via courier from super Dave in langeley bc. I went to the festival after I ordered the part , hence I was out of wifi range . Thank you all for your input, in about one hour I will know if the tci will fix it. If not iwill us your other leads. "Beloved" festival was simply heavenly, very sweet energy, a bit of a chickflick of a festival . So I feel well nurtured now by you and all the kind hippie chicks. You all rock . More in a few hours
                    • jurgenkoppen
                      • Jul 2007
                      • 97
                      Up 'n runnin...
                      Yo, good people. It was the tci . Plugged in the 'new' one, and she is purrin like the proverbial pussy. Thank you all again, it is good to be connected to folks who care . . PS: I'm sort of glad my destruction of the old tci was not destroying a good part. Makes me feel slightly less goofy. Rockin on...
                      • MrOzz
                        • Aug 2008
                        • 782
                        • Massachusetts
                        Glad you found the problem. Have a safe ride home.
                        1980 XS 1100SG
                        Pod Filters
                        DynoJet Kit
                        T.C.'s Fuse Block
                        V-Max Auto CCT
                        • Poprock
                          • Apr 2005
                          • 594
                          • Oregon Coast
                          That's good news. Woulda waved when you went by Tillamook if I'd known when. Have a great trip home. The weather is sweet right now. Say "Hey" when you head south again.
