Where is my diaphragm?
Dat I ain't so sure about. My bike ran like crap when the advance diaphragm went out.Greg
The list changes.Comment
The bike may run ok without the vacuum advance hooked up, but gas mileage will suffer, as the timing curve is designed with the vacuum advance in mind, and to get enough advance without it you need too much advance at low RPM. That said, at least one type of carb it's been figured out how to modify to provide the proper vacuum for the advance, so I expect it can be done for the others since they are the same carbs, they just don't have the ports drilled on the ones not setup for the 11. (at least on the bs34's, but the port exists in the casting, it's the same casting for all of them (at least for a given series such as the series III, but the difference is how the passages are drilled and the jet sizes.Cy
79 carbs
I've got an extra set of 78/79 carbs. PM me if you need them to get riding.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
You could, but it's a bit trickier than that. The vacuum nipple on the stock carb has a tiny hole into the carb throat, it's not the full 3/16" diameter. And where it is is important too; the stock hole is located so that it's blocked when the throttle plate is closed, and as soon as the plate moves the hole is subjected to 'manifold' vacuum.
Do a forum search; somewhere on here is a post about doing just this, and it details where and how big the hole is...Fast, Cheap, Reliable... Pick any two
Where's your diaphram?
Oh, man, lighten up. It's not that technical (Heh.), your diaphram is between your stomach and your lungs. Geez! don't put a hole IT!! ....had to do this.GenoComment
IMHO............get the right carbs for the bike.Greg
