picked up a 1980g
  • picked up a 1980g
    over the weekend i picked up a 1980g, the po had partly
    stripped the bike with the intention of doing it up which never
    eventuated, i got it for $400, the bike was mostly complete,
    he had butchered the wiring loom, im using a loom from my
    81rh, he had butched the pick up coil wires, the brakes are shot and will need rebuilding, he put the wrong spark
    plugs in, put a wrong size allen bolt into the timing case and
    cracked the upper case housing(repairable), had dripped brake
    fluid over a lot of the parts he had crated up (headlight cover
    tach/speedo and other bits and pieces, i was a bit dissapointed in that
    the engine and frame numbers dont match tho both the frame and engine
    are 80 models.
    the good news is ive got most of the parts from my spare rh to get the bike running.
    heres a few pics, i really like the standard and ill more than likely do a ground up resto on it.
    these were the carbs that came off the bike, not sure what there off originally tho.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    80g
    Pete.. Not sure that is an 80G?? It has the rear cowling on the seat and the foot pegs look to be 78/79. Somone correct me if I'm wrong?? Is it possible the European models had the cowling??
    78 XS1100E Standard
    Coca Cola Red
    Hooker Headers
    http://i408.photobucket.com/albums/p...m/DSC00580.jpg
    1979 XS1100 Special
    http://i408.photobucket.com/albums/p...m/DSC00612.jpg
    1980 XS Standard
    http://i408.photobucket.com/albums/p...m/DSC01137.jpg
    2006 Roadstar Warrior
    http://i408.photobucket.com/albums/p...um/warrior.jpg
      hi foreda,
      the engine and vin numbers start with 3x1 and date of manufacture
      say thats its an 80 model, this is my first standard so not sure what the
      differences would be between countries.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        foreda, just saw a thread u posted a little while back
        about the 80 u purchased, nice bike btw, i noticed the
        foot pegs on urs are in a different location than mine, the pegs
        on my 80 sit up a little higher and further back than the us models
        same is on my rh model.
        one of the guys on the aussie site has an 80g that also has the rear
        seat cowl, so it maybe a stock fitting for the bikes over here.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
          IIRC all the European standards had the cowling no matter the year. Only in the North American market did they get rid of the cowling and I believe even change the seat pan etc, the standards being pretty much the same frame and such through the whole run unlike here where only 78 and 79 were static with it morphing from there becoming more and more special like, with the H even using the special exhaust and mounting points but still with the standard tank writ large and the fairing as standard equipment.
          Europe didn't really have a special, not like the North American special at least, as it was really just an optioned up standard, no different frame and exhaust like we got.
            Pete, those pickup coils won't work correctly.
            The timing plate and coils have to move freely, like a Lazy Susan, and the thick replacement wires that have been put on there with heavy tape/shrink tubing won't allow the vacuum advance to do its job.
            Try to find something flexible like multimeter wires and don't solder them, just use a barrel crimp and only add enough tape or shrink tubing to keep the joint from shorting.
            Other than that: Nice find!
              hey scott,
              yeah i know, i just posted that pic from what the po attempted to do
              with his fix for the pick ups, ive used a spare set from my parts bike that works,
              in that same pic the po had used the incorrect plugs luckily the plugs had a
              short reach and im hoping no damage has been done.
              ive got all the wiring sorted out except ive go no headlight, tho the pass button activates the high beam, this isnt the type that needs the engine running for the headlight to come on? it has an off/park/on switch, the parking lights all work.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
                Pete,
                Look between the coils under the tank. See if the headlight relay is in there. If you have not seen one yet, they are square and have a four wire connector. IF the relay is there, then the headlight will not come on until the alternator is providing juice.
                  80 g
                  Yes Pete, I recently pick up a 80G with very low mileage and am not too far for completing restoration. Only thing left is repaint, find new seat cover and new tires. This one is going to look as good as my 78.I'll post some pics when I'm done.
                  I was thinking ther were differences between Eoro and American models but did not know what all the differences were. Have fun with the restore.
                  78 XS1100E Standard
                  Coca Cola Red
                  Hooker Headers
                  1979 XS1100 Special
                  1980 XS Standard
                    Originally posted by DGXSER View Post
                    Pete,
                    thanx don, i used the wiring loom from my 81rh so there would be no
                    relay there, guess ive got more looking to do, other than that everything
                    is working electrically at this stage.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                      im not sure of all the differences either at this stage, same with the 81 special and my 81 rh, theres a few differences there as well.
                      ur 78 looks real sweet, im sure ur 80 will come up looking just as good.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
