CCT conversion
  • James England
    • 3039
    • North of England
    #61
    Originally posted by WMarshy
    With the copper crush washer and all I figured it needed a lot
    I don't think it's a crush washer. It's just a copper sealing washer, like the ones on the brake line banjos. Or is that what you call a crush washer? I thought they kind of collapsed when tightened...
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      #62
      Yeah, same difference in my book...
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • James England
        • 3039
        • North of England
        #63
        Yep, same on Wikipedia...
        "The term washer is often applied to various gasket types such as those used to seal the control valve in taps. Crush washers, made of a soft metal such as aluminium or copper and used to seal fluid or gas connections such as found in an internal combustion engine."
        I must have been thinking of something like a sparkplug washer... which actually collapses as you tighten up. I think they're meant to assist in not overtightening, as they collapse once the required torque is reached. Or, worryingly, this might be a completely 'false memory'. ...these days I never know.....
        Nice to know my CCT has the correct one on it..a hefty copper one....it certainly doesn't leak.
          #64
          "The term washer is often applied to various gasket types such as those used to seal the control valve in taps. Crush washers, made of a soft metal such as aluminium or copper and used to seal fluid or gas connections such as found in an internal combustion engine.".
          You're probably thinking of a crush sleeve, which is used to set bearing pre-load. You torque those until the preload is good; they 'crush' in length...
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            #65
            Cool, thanks for the explanation. Like I said, don't use much more than 20 ft/lbs, they will snap!
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            • James England
              • 3039
              • North of England
              #66
              Def worth knowing. Like yours, my two took a hell of a lot of undoing, so I thought, "better really tighten them up hard". Looks like I was lucky and didn't overdo it. Nice that they come in pairs usually though, eh? My other one found a new home on an XS100 here in the UK.... I better e-mail him with that torque figure........
