Yowser, you are on the way. Between now and then, if you can set the bowls upright, and fill them half full of acetone, then let them set, you will disolve most of the dried fuel gunk that is in there. Put some Saran wrap over the top of the bowls to slow down evaporation.
When you are done, pour the acetone into an oil can, mixed 50/50 with ATF, and you have the Used Car Lot Mechanics po-boy rendition of PB Blaster or Kroil.
CZ
