Petcocks?
  • XSTrey11
    • May 2011
    • 111
    • Carbondale, Illinois
    Petcocks?
    Hello XSives! I found a replacement petcock on Ebay for my faulty left petcock and its only about $25 which seems to be the price of a rebuild kit but it says it's for a special. It looks the same as mine but I figured I'd better check to make sure it will fit before bidding. What do you think?
    1980 XS11G 22XXX miles.
    • 8796
    Petcocks from Standard and Special won't interchange, different bolt spacing. Maybe it was listed wrong though, if you post a link someone can tell you.
    • XSTrey11
      • May 2011
      • 111
        That's for a Special, and won't fit a standard tank. Incomplete too; the hose barbs are missing, and aren't generally replaceable as they're pressed-in...
        Which fuel tank do you have? The larger 'bread box' standard tank, with it's flush fuel cap, or do you have a Special tank with the conventional surface-mount cap? Tank swaps are common.
        You might want to just bite the bullet and get a rebuild kit, as anything used you may buy may not be any better than what you have...
        • XSTrey11
          • May 2011
          • 111
          I have the big one with the gas cap that's in the center and flush.
          • XSTrey11
            • May 2011
            • 111
            how about this one?
              That looks like the winner. It looks to be for a Standard tank and even has the filter tower in place.
              • XSTrey11
                • May 2011
                • 111
                S*** that one got bought...guess I'll just get the kit but what I'm worried about is in all the kits I see there are two cross sections in the big oval rubber o-ring on top and my petcocks do not have a slot for those sections.
                  Can you post a pic of your petcocks?
                  • XSTrey11
                    • May 2011
                    • 111
                    I'm currently at work but I'd be happy to at about 5pm central time.
                    • XSTrey11
                      • May 2011
                      • 111
                      here's the guts of the faulty left petcock
                      and this is the functional right petcock
                      let me know if you need a better picture or something more specific.
                        Mine look like yours. The kits I have seen often show the partitioned piece but don't come with it cause they use a stock picture, not an actual picture of the kit. I believe the special uses the partitioned one though, so make sure your getting the right kit and not one for a special, and if your going to do the kit, get both kits, georgefix sells a set in a pair so you can do both sides at the same time, and they are right, I've installed one of his kits, you MIGHT need to stretch the spring a little to get them to seal when the engines not running but that's the only issue I saw.
                          Originally posted by cywelchjr
                          Mine look like yours. The kits I have seen often show the partitioned piece but don't come with it cause they use a stock picture, not an actual picture of the kit. I believe the special uses the partitioned one though, so make sure your getting the right kit and not one for a special...
                          Interesting... they changed the design of the standard petcock after at least '79. Yours are definitely standard versions, but without the 'partition' in the sealing o-ring. All of my standard petcocks have that weird o-ring, and the filter tower is different too. The filter is held in with a rivet, not a press fit... it's a bitch to get out.
                          Unless these are off some other Yamaha and happen to be very similar...
                          • XSTrey11
                            • May 2011
                            • 111
                            By "partition" you mean the two like cross bars in the big oval shaped o ring on top right? That's what I'm having trouble finding in a kit they all have those two cross sections.
                              Yeah my 78 petcocks are different as well. Mine have the partitioned o ring and the different tower like steve is talking about.
                              Even if the kit came with the partitions you could just trim the pieces off anyways.
