New Seat Cover XS1100E
  • russell
    • Aug 2002
    • 44
    • sydney australia
    Have just received a replacement seat cover. Any idea on how and where do I start when placing the cover over the base unit? Do I start at the rear and work my way forward??? Dont want to stuff this up and have a saggy cover.
    Also what paint did Yamaha use on the Brake Calipers. Is it the PJ1 Satin Engine or the Gloss?
    Many Thanks to anyone who can help
    • 9981
    Start in the middle where the crease is and work your way out on the cover.
    I don't know what paint YAMAHA used on the calipers but the high heat ceramic seems to work best to resist the brake fluid.
    IMHO
    • James England
      • 3039
      • North of England
      I'd put the cover on the foam so that the top of the seat cover is lined up correctly on the foam. Then, with the seat facing forwards as if on the bike, I would take one side down to the seat pan and secure it, but without making the top of the cover move on the foam. Then do the other side. Then work your way forwards and then backwards, securing as you go. The trick is to get the seat cover sufficiently stretched so as not to sag but not enough to start pulling the quilted area on the top of the cover too much so that it moves on the foam. Too tight and you'll have too much tension on the cover. On replica seats, the cover is only GLUED down under the seat pan... no metal pins or sharp bits to hold it.
      The original finish on the calipers was gloss. I did all mine in PJ1 satin black case paint. It doesn't resist brake fluid though. I had a weep at the back and it took the PJ1 off. IMO, the PJ1 looks a lot better than the OEM gloss.......
      • russell
        • Aug 2002
        • 44
        • sydney australia
        Thanks for the info
        Have the OEM seat. Had some rust in the base of the seat. Used Por 15 paint to repaint the seat. Will attempt the cover replacement this weekend!!! Just hope none of the meatal tabs under the base break off.
        Also have ordered the PJ1 paint. So far the restore project is going as planned.
        Thank god there is the internet
          • 7831
          If you have a few tabs break, you can use SHORT sheet metal screws or pop rivets in place of the tabs.
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            Another method is to take the pan down to your local old tyme sheetmetal shop, along with some beers or other cumshaw, and get the old tyme tinner to use his hand notchers on the edge of the pan.
            He will have to jury rig a stop on the tool, so that the original tabs are replicated when the tool is used.
            CZ
