no fire in 2&3
    Looks like.
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      You're right at the mileage those black coils are known to die at. It's a pretty common failure mode there, just the way it normally happens. I had been thinking it had to do with soldering the primary wires to them, but the survey says that the ones failing had NOT had that done so my theory was proven wrong. It's now my theory they are just crap and should be avoided and one should go with ANYTHING but the MikesXS black coils.
      • kevxs
        • Apr 2009
        • 353
        • toronto
        thats a shame, i thought i was reading people were getting 8000 or 10000 out of them, 2000 seems pretty sad. anyway guess i gotta get the green ones.
        1979 XS1100SF 37000km
        Green Dyna Coils
        Stainless Brake Lines
        1973 CB100
        kevXS
          Get the dyna coil version is the green ones. Cheaper and warrantied.
          • kevxs
            • Apr 2009
            • 353
            • toronto
            can you send me the link for those?
            Green Dyna Coils
            1973 CB100
            kevXS
              About 95% sure these are the right ones.
              http://www.z1enterprises.com/detail.aspx?ID=210
              • MrOzz
                • Aug 2008
                • 782
                • Massachusetts
                Those are the right ones.
                Z1 seems to have the best price for them. Thats where I bought mine.
                1980 XS 1100SG
                Dyna 3 Ohm Hi Output Coils
                Pod Filters
                DynoJet Kit
                T.C.'s Fuse Block
                V-Max Auto CCT
                  Check your pickup coils... and you don't have to dig out that plug behind the fuse panel, check it at the TCI instead; this will also 'prove' all the intervening wire. You should have 720 ohms (+/- 20%) on each coil, more is not good. This will be the smaller plug at the TCI, check between the two yellows and two whites. It's a good idea to have the engine cover off and move the timing plate by hand to check if the wires are making intermittant contact.
                  • cywelchjr
                    • 4450
                    • Sacramento, CA
                    It would be worth checking except he already swapped the primary wires and the symptom didn't move, showing that the coil is bad, which has come to be expected with the black MikesXS coils, and right about the number of miles he has on them, so given the coils he has and the miles he has on them, it's the first thing to check, given that it's so far pretty much a 100% rate of failure on at least one of the coils at right about 2000 miles.
                    • James England
                      • 3039
                      • North of England
                      Originally posted by kevxs
                      so when i switch the orange and grey wires, i still dont get fire in 2 & 3. i guess this means my coil is bad?
                      Yes. It could possibly be both plugs/caps and leads.... logically speaking..... but it won't be. It'll be the coil, I'd say.
                      Those Mike's XS coils sound complete rubbish. When I was looking into changing mine (I have green 3 ohm Dynas on now, bought from the US), I contacted them, asking about those coils and if they could send to me here. How pleased I am that I received a one-word response "No". I was disappointed at the time but things often work out for the best.
                      OEM coils often NEVER need replacing and there's a healthy market in used oines, so even 10,000 miles seems poor.....
                      • kevxs
                        • Apr 2009
                        • 353
                        • toronto
                        will i be able to use the plug wires off my mikeXS black coils on the new green dyna coils or do i have to buy new wires too?
                        Green Dyna Coils
                        1973 CB100
                        kevXS
                        • mxmikie
                          • Aug 2008
                          • 482
                          • Bouse az
                          i used a set of coils from a honda vf750
                          • James England
                            • 3039
                            • North of England
                            On Dynas you only get the coils themselves. So you'll need HT lead and the rubber shrouds that seal them... also the little brass inserts that go into the HT lead sockets of the Dynas. All on eBay and not expensive.
                            I'd buy silicone HT lead with carbon core, the brass bits, and then make your own leads. The silicone leads are excellent and better than plastic sheathed copper. They are lower resistance, giving a better spark one assumes, and flexible. Here's pix of my Dyna mountings etc... just a couple of little L brackets per coil and using the original bolts.
                            https://
                            https://
                            • kevxs
                              • Apr 2009
                              • 353
                              • toronto
                              so i cant use the HT wires that i installed last year when I got the black coils?
                              kinda on a budget here . . .
                              Green Dyna Coils
                              1973 CB100
                              kevXS
                              • James England
                                • 3039
                                • North of England
                                Oh yes, you can. I thought the leads were moulded into the MikesXS coils. Obviously not. Yes, just use those...
