no fire in 2&3
  • kevxs
    • Apr 2009
    • 353
    • toronto
    no fire in 2&3
    i lost cyl 2&3 on my ride home friday.one minute they worked next they didn't.
    i put in new black mikexs coils last season (2000 km ago) and did the broken wire fix.
    right now i'm checking for more broken wires but they seem ok so far. (i'll keep looking)
    in the mean time, what other diagnostics can i do to trace this problem?
    when i swap the plug wires (1 to 2 and 3 to 4) and switch the orange and grey wire on the TCI 2&3 fire but not 1&4.
    seems to defiantly be an electrical problem of some kind, as i say i'll keep checking for broken wires as this is the most obvious problem but other suggestions are appreciated!
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
    Test the coils. That sounds like about the average number of km's that those coils last before they fail.
      1 & 3 are on the same coil and 2 & 4 are on the other. It's probably a plug wire or boot problem.
      Unscrew the boots an trim about 1/4" off each wire and re install the boots and see if that helps.
      • kevxs
        • Apr 2009
        • 353
        • toronto
        i forgot about the coils, i was thinking 1&4 and 2&3 were on the same coil. so it seems my coils are working but only on 1 cyl each. strange. the wires and boots are quite new but i'll trim some and try anyway.
        funny how this happened without warning, there were no intermittent problems before this happened it just quit about 1 min after leaving work and i drove home on 2 cylinders
        Green Dyna Coils
        1973 CB100
        kevXS
          If you have replaced the wires on stock coils, you might want to check your work at the coils too. You may have lost connection, or gotten some moisture in there.
          • James England
            • 3039
            • North of England
            Wrong.
            1 and 4 are on the same coil and 2 and 3 on the other
            You have one ignition coil or pickup/wire etc that's not working. If you just switch the orange and grey LT wires and leave all the HT caps unswitched, the lack of spark will go to 1 & 4. Betcha
              James is right. Sorry
              That means it could be, and probably is, the pickup coils.
              • MrOzz
                • Aug 2008
                • 782
                • Massachusetts
                Originally posted by kevxs
                ...funny how this happened without warning, there were no intermittent problems before this happened it just quit about 1 min after leaving work and i drove home on 2 cylinders
                Close to the same issue I had when my MikesXS black coils failed.
                1980 XS 1100SG
                Dyna 3 Ohm Hi Output Coils
                Pod Filters
                DynoJet Kit
                T.C.'s Fuse Block
                V-Max Auto CCT
                  Silly greg! I am still guessing it is the mikes xs black coil plague...
                  • kevxs
                    • Apr 2009
                    • 353
                    • toronto
                    multimeter testing
                    i think my coils are good . . .
                    i have 15k ohm resistance between my 1&4 plug wires and the same reading for 2&3
                    i think i have about 1.5k ohm resistance between by yellow (with stripe) wires on the TCI and the same reading for the white (with stripe) wires on the TCI.
                    am i correct that it is likely a broken pickup wire?
                    Green Dyna Coils
                    1973 CB100
                    kevXS
                      Take off the left engine cover and check the pickup coils. The plug for them is behind the fuse panel.
                      There is a thread on testing and repairing them here....
                      • James England
                        • 3039
                        • North of England
                        It's easy to establish if it's one of the coils and I wouldn't trust the multimeter thing too much at this stage.
                        Just switch the orange and grey wires. If the no-spark stays on the same two plugs, it's the coil/leads/HTcaps. If the no-spark moves to the other plugs it's NOT the coil.
                        When you did the switching, you switched HT caps too and that doesn't really help you along in the diagnosis. Lots of people havereported how rubbish the MIkesXS coils are
                        So... switch the orange and grey and get back with your report!
                          Good point James.
                          • James England
                            • 3039
                            • North of England
                            It's good if you have sparks at one set of plugs. You can just switch one thing at a time and see if the fault moves. The problem with the multimeter tests is that I've found the results don't necessarily indicate the truth. Switching a known working component which is already on the bike (instead of having to buy it) is the way to go with the ignition. If the no-spark moves after the orange/grey switch, that means it's not the coil but somewhere in the pickup circuit. The orange and grey should then be switched back to their correct positions and you can then do a switch of the pickups. Same thing... if the fault doesn't move after switching, it's not the pickup etc.
                            • kevxs
                              • Apr 2009
                              • 353
                              • toronto
                              so when i switch the orange and grey wires, i still dont get fire in 2 & 3. i guess this means my coil is bad?
                              Green Dyna Coils
                              1973 CB100
                              kevXS
