Floats
  • jedi50036
    • Aug 2010
    • 25
    • Boone, Iowa
    Floats
    Can someone please tell me where i can get floats fr my 79 xs11 special? I have looked all over and all i can find are rebuild kits but the do not come with the floats. I have one that has a hole by where the float is welded to the holder.
    79 xs 11 Special
    Partsnmore.com shows this brass float when you search Yamaha; XS1100 and then Universal, first page below air filters:
    Carb Float #20-6500
    Brass Carb Float Fits VM29/33 Smoothbores & most OEM CV/VM Mikuni carbs Used on Yamaha & Kawasaki up to 1980 $13.00 ea.
    However, the above float has the same part # as the ones on MikesXS.net, and I've read where folks have stated that those floats do NOT fit/work on the 1100 carbs?
    Others have reported that you can use the newer plastic type floats in the older carbs. But I think they had to bend the floats a little inwards to keep them from rubbing/hanging on the float bowl walls!
    Hopefully others will chime in.
    • davidsymons53
      • 197
      • Peterborough, Ontario
      MikesXS has floats for Mikuni BS38 carbs. I don't know if they fit our BS34 carbs but it might be a place to check.
      http://www.mikesxs.net/products-35.html#products
      David
      1981 XS1100 Special
      Previous Bikes
      1999 Honda Goldwing Aspencade 1500
      1983 Honda Goldwing Aspencade 1100
      1982 Honda CB900c
      1984 Honda vt750 Shadow. My son's bike now.
      1984 Honda vt500 Shadow
      • jedi50036
        • Aug 2010
        • 25
        • Boone, Iowa
        Ii looked at those and the one on mikes says its for a xs650. Is there a big difference in size? the picture looks just like the ones i have.
        79 xs 11 Special
        • mack
          • 2411
          • Ontario, Canada
          Floats
          Well I've been puttering away with my carbs for a week now. To sick to do much else. I've discovered a couple things. First thing is don't order the plastic floats that come from tiwain or china. Each float is different not only from each other but also from one side to the other on the same float. Where the my old brass ones are all the same. Using the center of the pivot point as datum, the brass ones measure 27 mm to the bottom of the brass. The plastic measured 32.8mm give or take a 1.5 mm. So if you wanted to achieve the same fuel hieght in the bowl with the plastic, the measurement would be 22-23mm. Problem is the plastic floats bottom out on the main cross over tunnel at about 22.7mm. Now I know they are solid so I'm going to grind down the floats so I can hit 22mm without touching the cross over and try to make both sides the same. Now "Bullet" uses a different plastic float that may be drop in capable. Dan if your out there chime in with your source and part number.
          I'm putting my old brass ones back in for now and just testing on a spare set.
          Also of some interest. I measured my original float valves with washers from bottom of the washer face up to the top of the spring loaded pin. The original valves and pins measured 9.37mm, new replacements 8.31mm and the viton tipped assemblies measured 9.03mm. To make a long story short, 25.7 mm float heights need to adjusted accordingly. Nothing is hard and fast anymore.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
            • 7780
            Mike\'s XS brass floats will be for BS38 carburetors. The XS650 went to BS34 carburetors when they were all plastic floats, IIRC. I can\'t say how close the float bowls are between BS38 and BS34 carbs.
            Marty (in Jamaica, NY)
            • gggGary
              • Jun 2012
              • 6
              • Baraboo, Wi.
              Ran into this while doing a bit of float research and thought I would update the thread for anyone looking for float info.
              The XS650 used BS38s from 1970 to 1979. In 1980 the bikes sold in North America switched to BS34s. 1980 only BS34s used brass floats. 1981 through 83 they had plastic floats. The BS34 floats do not fit into BS38s and vice versa. You can interchange brass and plastic floats in BS34s but will need to use the appropriate float height. The Mikes XS carb parts of all types are generally avoided by the XS650 guys, as mentioned, they are poorly made Chinese knock offs. I believe Sudco sells better quality parts, but they also list some floats that are suspiciously cheap..... Probably a very bad part to be cheap about.
              JBM sells replacement diaphragms for BS34 and BS38 carbs
              http://jbmindustries.com
              There are some replacement needle valves for BS34 that can be adjusted and you can add a small washer under seat in the slide that richens the BS34s a tad, that helps with just off idle stumble in the XS650 anyways.
              ta ta for now.
              gggGary
              79 SF/ XS650
              old guy no expert
                • 7780
                Sirius Consolidated Inc has a variety of floats to offer in plastic. I assume they're from varying sources and maybe quality. (They offer genuine Mikuni.) They also offer the brass floats. My limited experience with this vendor has been excellent.
                • MPittma100
                  • Aug 2011
                  • 2359
                  Carb Floats
                  Marty,
                  Yamaha Dealer (online) NW Vintage Cycle Parts (NWVCP.com) has them. Part number is 2A2-14985-01-00. Bike Bandit also has them (for more $).
                  MP
                  1981 XS1100H Venturer
                  K&N Air Filter
                  ACCT
                  Custom Paint by Deitz
                  Geezer Rectifier/Regulator
                  Stebel Nautilus Horn
                  EBC Front Rotors
                  Limie Accent Moves On In 2015
                  Mike
                  • MPittma100
                    • Aug 2011
                    • 2359
                    Carb Floats
                    Marty,
                    Best deal that I have seen on floats is on Ebay. The dealer is siriusconincnosparts. I have had good luck with them in the past. The item number is 130795626924. Price is $29.97 and shipping is free. They are offering it under the Yamaha p/n 2A2-14985-01-00 (the correct number).
                    MP
                    K&N Air Filter
                    ACCT
                    EBC Front Rotors
                    Mike
                      Marty,
                      MP
                      Or you could go to SCI's website and buy direct and avoid the ebay price increase.
                        • 7780
                        We're all talking about the same company. I found Sirius Consolidated on eBay. I found their website on their About Me page. I prefer to avoid eBay in this kind of situation.
                        • MPittma100
                          • Aug 2011
                          • 2359
                          http://www.siriusconinc.com/
                          Yes, I see here that the same part (float) is only $17.50. Interesting price difference.
                          MP
                          K&N Air Filter
                          ACCT
                          EBC Front Rotors
                          Mike
                            MP
                            Ebay fees are terrible!
                              • 7780
                              Many businesses are making sales on eBay due to its popularity. This makes eBay a great search engine. By eBay's rules, you may only post your website on your About Me page. That is how I find many great sites.
