Can someone please tell me where i can get floats fr my 79 xs11 special? I have looked all over and all i can find are rebuild kits but the do not come with the floats. I have one that has a hole by where the float is welded to the holder.
Floats
Partsnmore.com shows this brass float when you search Yamaha; XS1100 and then Universal, first page below air filters:
Carb Float #20-6500
Brass Carb Float Fits VM29/33 Smoothbores & most OEM CV/VM Mikuni carbs Used on Yamaha & Kawasaki up to 1980 $13.00 ea.
Others have reported that you can use the newer plastic type floats in the older carbs. But I think they had to bend the floats a little inwards to keep them from rubbing/hanging on the float bowl walls!
Hopefully others will chime in.
T.C.T. C. Gresham
MikesXS has floats for Mikuni BS38 carbs. I don't know if they fit our BS34 carbs but it might be a place to check.
http://www.mikesxs.net/products-35.html#products
David1981 XS1100 Special
Previous Bikes
1999 Honda Goldwing Aspencade 1500
1983 Honda Goldwing Aspencade 1100
1982 Honda CB900c
1984 Honda vt750 Shadow. My son's bike now.
1984 Honda vt500 Shadow
Floats
Well I've been puttering away with my carbs for a week now. To sick to do much else. I've discovered a couple things. First thing is don't order the plastic floats that come from tiwain or china. Each float is different not only from each other but also from one side to the other on the same float. Where the my old brass ones are all the same. Using the center of the pivot point as datum, the brass ones measure 27 mm to the bottom of the brass. The plastic measured 32.8mm give or take a 1.5 mm. So if you wanted to achieve the same fuel hieght in the bowl with the plastic, the measurement would be 22-23mm. Problem is the plastic floats bottom out on the main cross over tunnel at about 22.7mm. Now I know they are solid so I'm going to grind down the floats so I can hit 22mm without touching the cross over and try to make both sides the same. Now "Bullet" uses a different plastic float that may be drop in capable. Dan if your out there chime in with your source and part number.
I'm putting my old brass ones back in for now and just testing on a spare set.
Also of some interest. I measured my original float valves with washers from bottom of the washer face up to the top of the spring loaded pin. The original valves and pins measured 9.37mm, new replacements 8.31mm and the viton tipped assemblies measured 9.03mm. To make a long story short, 25.7 mm float heights need to adjusted accordingly. Nothing is hard and fast anymore.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186
Mike\'s XS brass floats will be for BS38 carburetors. The XS650 went to BS34 carburetors when they were all plastic floats, IIRC. I can\'t say how close the float bowls are between BS38 and BS34 carbs.
Marty (in Jamaica, NY)Marty (in Mississippi)
Ran into this while doing a bit of float research and thought I would update the thread for anyone looking for float info.
The XS650 used BS38s from 1970 to 1979. In 1980 the bikes sold in North America switched to BS34s. 1980 only BS34s used brass floats. 1981 through 83 they had plastic floats. The BS34 floats do not fit into BS38s and vice versa. You can interchange brass and plastic floats in BS34s but will need to use the appropriate float height. The Mikes XS carb parts of all types are generally avoided by the XS650 guys, as mentioned, they are poorly made Chinese knock offs. I believe Sudco sells better quality parts, but they also list some floats that are suspiciously cheap..... Probably a very bad part to be cheap about.
JBM sells replacement diaphragms for BS34 and BS38 carbs
http://jbmindustries.com
There are some replacement needle valves for BS34 that can be adjusted and you can add a small washer under seat in the slide that richens the BS34s a tad, that helps with just off idle stumble in the XS650 anyways.
ta ta for now.
gggGary79 SF/ XS650
old guy no expert
Sirius Consolidated Inc has a variety of floats to offer in plastic. I assume they're from varying sources and maybe quality. (They offer genuine Mikuni.) They also offer the brass floats. My limited experience with this vendor has been excellent.Marty (in Mississippi)
Carb Floats
Marty,
Yamaha Dealer (online) NW Vintage Cycle Parts (NWVCP.com) has them. Part number is 2A2-14985-01-00. Bike Bandit also has them (for more $).
MP1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
Mike
Carb Floats
Marty,
Best deal that I have seen on floats is on Ebay. The dealer is siriusconincnosparts. I have had good luck with them in the past. The item number is 130795626924. Price is $29.97 and shipping is free. They are offering it under the Yamaha p/n 2A2-14985-01-00 (the correct number).
K&N Air Filter
ACCT
EBC Front Rotors
Mike
MP
http://www.siriusconinc.com/Nathan
Originally posted by natemoen View PostOr you could go to SCI's website and buy direct and avoid the ebay price increase.
K&N Air Filter
ACCT
EBC Front Rotors
Mike
Originally posted by MPittma100 View PostYes, I see here that the same part (float) is only $17.50. Interesting price difference.
MPNathan
