swingarm alignment
    swingarm alignment
    how do you actually go about measuring the clearance or alignment of the swing arm?
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Using a caliper measure the gap between the frame and the swing arm on left and right sides. There should be no more than 1.6mm 0.062in. Difference between left and right side gaps.
    To adjust, remove chrome caps loosen locknuts,loosen the shaft with the greater gap 1/2 turn at a time tighten the opposite side to 43-52 foot lbs.
    Check gaps when they are good tighten lock nut to 72lbs.
    Rick
    650SF
    XS1100SG Project bike
      Rick
      There is basically no room to get a caliper in there!
      Also the 43-52 foot pounds is a misprint! it is supposed to be INCH pounds!
        Rick
        No No No No No! That's inch pounds! That is a misprint in some manuals and if you crank it down that tight you may well fubar your frame. The lock nut is correct, but the 43-52 is inch pounds (and double checking it I found it is correct in my yamaha factory manual).
        • Rickrod3
          • Jun 2009
          • 721
          Thanks for the correction. Nate I have gotten a caliper in there it is a paine.
          I was thinking couldn't a feeler gauge be used?
          Is 1 inch pound 1/12 of a foot pound?
          Rick
          PS glad CY and Nate caught it before I caused you any greif
          650SF
            Rick
            Yes, but at those levels, unless your using a cheap dial or bar type torque wrench, they don't go that low unless it's an inch pound wrench anyways. But it's good to know the conversion cause you can go the other way for low foot pound stuff with an inch pound wrench.
              That's why I am glad that my 1/4 drive torque wrench is in inch pounds.
                You can use a feeler guage between the frame and swingarm, I usually just eye it to make sure they are equal.
                  • 5073
                  Yeah, me too. The frame is not a precicely machined part!
