I just did my tank, this is what I did and what I would do different.
Here is what I did and my results. sorry no pics, my auto focus does not like it down in there.
First I rinsed it out with TSP (TriSodiumPhosphate) figuring it is a heavy detergent. It did some but could have done better. Then I added BBs. Note: everyone already knows but we want STEEL BB's. overall I had to much mass to do a good job by hand, my bad. I drained and used a magnet to get the BBs out. I then used a gallon on phosphoric acid (like $16 @ Home Depot), and topped it off with water. I tried a tip about using a straw or tubing to get the air pocket around the filler out but I could not get it to work for me. over all soak was around a day and a half. Looking at my results I would have been better off NOT diluting the acid but using less and swishing it about frequently, as I have an extreamly clean tank bottom but above the 1 gal line it was just not as effective (and the acid was undiluted for only a few min). drained, neutralised (H2O & Arm & Hammer), rinsed with H2O, rinsed with H20, rinsed with denatured alcohol. The alcohol came out with a bunch more varnish. so I repeated the alcohol. Let dry. sloshed some oil about. Results are alright but not totally great.
looking back over all:
I would talk to a rad shop
or get por15 (I hear its good stuff for DIY)
or if I was going to do this again:
Drain
rinse with alcohol a few times, with bbs on the last ones.
rinse with water then remove bbs (so you don't suck fumes)
use the phosphoric acid (enough to slosh around)
rinse with water and arm and hammer (pre disolved)
rinse with water
rinse with alcohol to get the last of the water.
oil it (if you were going to coat those products come as a kit so we would not be here)
That is how my adventure went and what I learned. I hope you have good results with whatever you choose. And one last note from me: while others may have had "Kreem" work for them, It did not do me well the time I tried it - which is why I went this way this time.
Drain
rinse with water
