I'm on the last lap of this restoration (XS1100 1978), The last issue is cleaning the rust out of the tank. I have been researching for several weeks now and found a product called METAL RESCUE. Seems to simple to be true. Has anyone here used this product ? and what were the results ?
Tank Rust
If you ate repainting the tank, just bring it to a radiator shop and have them hot tank it. This will remove almost all the paint.
I think the can do something to save.the paint bit it is more prep work and more money.Nathan
Theodore Roosevelt -
Friends and I have had good success with this relatively cheap method! If you're having trouble reading this thread or seeing photos let me know:
http://www.st-owners.com/forums/show...g-electrolysis
We were going to do this on Karla's XJ, but ended up just going with inline fuel filters as the rust wasn't that bad.Two weeks vacation does NOT make a life.
His: 2006 Ninja 650R, salvaged, 10k miles
Hers: '82 XJ1100 44.4k milesComment
A friend used Metal Rescue and said it was great. I have used Evapo-Rust and gotten very good results.
I still prefer a length of chain (easier to get out than nuts and bolts) inside the tank with the petcock removed and all holes taped over. Wrap with towels and use more to wedge in dryer. Tumble with NO heat and check every fifteen or twenty minutes. Most are done in half an hour or less.
Don't tell the old lady what yer doing; plan your timing carefully if necessary. And remember, it's better to ask forgiveness than permission.Comment
Hi Shack,I still prefer a length of chain (easier to get out than nuts and bolts) inside the tank with the petcock removed and all holes taped over. Wrap with towels and use more to wedge in dryer. Tumble with NO heat and check every fifteen or twenty minutes. Most are done in half an hour or less.
take the fuel level sender out too, eh?
And if you use chain in a Standard tank, it can get immovably stuck around the gas cap well vent tube.
By the time Mr Smart had worked out that it didn't really matter if it stayed there, Mr Stupid had chopped the tank open to remove it.
Anybody need a Standard tank with a big ugly seam weld buried in half a can of Bondo?
And how big is your clothes dryer? A gas tank sure won't fit in mine.Fred Hill, S'toon
"The Flying Pumpkin"Comment
dryer
using my dryer in that manner Sir, would have me divorced!
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
Dryer Idea Sounds AWESOME!...I like to use bbs though...u can count them as they go in if you want to make sure they all are out...but i always figured if it doesn't rattle must not have bbs left in it...a handful is what i use for measuring...Daily Driver - '04 Suzuki Marauder 1600
Project Bike - '79 XS1100 Special
Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
Ride Till You Die!
"MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
“Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
"When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"Comment
USE CLRI'm on the last lap of this restoration (XS1100 1978), The last issue is cleaning the rust out of the tank. I have been researching for several weeks now and found a product called METAL RESCUE. Seems to simple to be true. Has anyone here used this product ? and what were the results ?
Here is a link that you can check out...I'm going to try this next time i do a tank cleaning...click the first pic of the CLR...
From this:
To this:
Ride Till You Die!
I usually (except with Sporty and Wassel peanuts!) have to keep the door open and tape the little button down so the dryer will still run.
The CLR photos have changed my mind. I think I've got a new method to try out. Thanks for posting that.Comment
Ride Till You Die!
I wouldnt do this with a standard tank. To much of a risk of breaking the drain tube that runs inside the tank from the filler well. I would use it for a special tank, but for the standards I would use something else.A friend used Metal Rescue and said it was great. I have used Evapo-Rust and gotten very good results.
Don't tell the old lady what yer doing; plan your timing carefully if necessary. And remember, it's better to ask forgiveness than permission.Nathan
Theodore RooseveltComment
Clr
The CLR formula was changed. I heard it does not work on rust anymore. If anyone uses it let us know if it works on our tanks.
Thanks, David
Calcium Lime Rust, more commonly known as CLR, is a household cleaning product used for dissolving stains, such as calcium, lime, and iron oxide deposits, from material types found in western-style kitchens or bathrooms.
Its ingredients include water, lactic acid, gluconic acid, glycolic acid, sulfamic acid, citric acid, and surfactants. The product also contained phosphoric acid at one time, but it is now phosphate free. The phosphate free formula is slightly more environmentally friendly, but its effectiveness against some stains such as rust is greatly reduced.1981 XS1100 Special
Previous Bikes
1999 Honda Goldwing Aspencade 1500
1983 Honda Goldwing Aspencade 1100
1982 Honda CB900c
1984 Honda vt750 Shadow. My son's bike now.
1984 Honda vt500 ShadowComment
Thanks for the idea's. Have been traveling for work and unable to respond. As for the Dryer, I think the old lady....I mean wife would leave and take what little money I have left. Wait...that may be a good idea.1978 xs1000e New Project no name yet.
1981 xj650 JohndoComment
