i just picked up a set of k&n filters wondering what mods need to be done with the intake. also got a question about the engine advanced mechanism does the vacuum advance connect into the air box? thanks for the help
pod filter help
To swap to pods, you'll need to rejet/resync the carbs. You'll need to go up one or two jet sizes too; this will depend on what type of exhaust you have fitted.
As for the vacuum advance, that connects to the number two carb (not the intake); the nipple is on the top right near the manifold.Fast, Cheap, Reliable... Pick any two
Vacuum advace hose goes to port on front side of number 2 carb. Could'nt run fast enough to give me a set of pods, besides sometimes causing a tuning daymare. No mods if a Standard cept for a vented breather to replace the hose that goes crankcase vent up to front top of air box. Also, go back and edit your profile with the yr. scoot we're dealing with and your location as you see on the other members. Welcome to the XSessive madness!81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
pod filters
i have a kerker four to one exhaust right now. 110outside main jets 120 inside a 42.5 pilot jet. Was going to dyno tune but have to wait till fall due to construction.
p.s. hope to have bike back together within a few weeks will post lots of picturesLast edited by L0rdexpectati0n; 04-19-2011, 06:35 PM.1980 xs1100sg
Hey Lord,
You've got an 80 SG...checked your PROFILE to find it, would be good to put in your signature in future so folks don't have to check the profile.
Surprised that you have the 110/120 combo....most have found the same size across all four. Yamaha did away with the staggered jets early on, despite what the manuals say. The 81 came with 110 straight across, and a 120 is 4 sizes up. What do your plugs look like on the cylinders with the 120's? If you have good color, or even a bit sooty with the 120's, then that may be all you need, and just get 2 more to replace the 110's. It's a bit of a trial and error process sometimes!
T.C.T. C. Gresham
If you do get a dyna jet kit, stick with the stage 1 kit, anything else is too much for a basically stock engine.Nathan
Originally posted by L0rdexpectati0n View Poststock for nowNathan
