pod filter help
  • L0rdexpectati0n
    • Dec 2010
    • 45
    • outskirts of hell,MI
    pod filter help
    i just picked up a set of k&n filters wondering what mods need to be done with the intake. also got a question about the engine advanced mechanism does the vacuum advance connect into the air box? thanks for the help
    1980 xs1100sg
    To swap to pods, you'll need to rejet/resync the carbs. You'll need to go up one or two jet sizes too; this will depend on what type of exhaust you have fitted.
    As for the vacuum advance, that connects to the number two carb (not the intake); the nipple is on the top right near the manifold.
      Vacuum advace hose goes to port on front side of number 2 carb. Could'nt run fast enough to give me a set of pods, besides sometimes causing a tuning daymare. No mods if a Standard cept for a vented breather to replace the hose that goes crankcase vent up to front top of air box. Also, go back and edit your profile with the yr. scoot we're dealing with and your location as you see on the other members. Welcome to the XSessive madness!
      • L0rdexpectati0n
        • Dec 2010
        • 45
        pod filters
        i have a kerker four to one exhaust right now. 110outside main jets 120 inside a 42.5 pilot jet. Was going to dyno tune but have to wait till fall due to construction.
        p.s. hope to have bike back together within a few weeks will post lots of pictures
        1980 xs1100sg
          Hey Lord,
          You've got an 80 SG...checked your PROFILE to find it, would be good to put in your signature in future so folks don't have to check the profile.
          Surprised that you have the 110/120 combo....most have found the same size across all four. Yamaha did away with the staggered jets early on, despite what the manuals say. The 81 came with 110 straight across, and a 120 is 4 sizes up. What do your plugs look like on the cylinders with the 120's? If you have good color, or even a bit sooty with the 120's, then that may be all you need, and just get 2 more to replace the 110's. It's a bit of a trial and error process sometimes!
          • L0rdexpectati0n
            • Dec 2010
            • 45
            still rebuilding it right now, rebuilt the carbs last month according to the service manual going to get a dyna jet kit when i can get it tuned but i will keep an eye on the spark plugs till then
            1980 xs1100sg
              If you do get a dyna jet kit, stick with the stage 1 kit, anything else is too much for a basically stock engine.
              • L0rdexpectati0n
                • Dec 2010
                • 45
                stock for now
                1980 xs1100sg
                  Originally posted by L0rdexpectati0n
                  stock for now
                  Well unless you plan on dropping MAJOR money into the engine use the stage one. And when I say major I am talking like the kind of money and mods involved in using an fj 1200 engine in a legend race car.
                  • L0rdexpectati0n
                    • Dec 2010
                    • 45
                    yes you are right in that since $=horsepower so all in due time
                    1980 xs1100sg
