what do i need to take apart the mc
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    maybe there's a write up? I know there's a write up on how to reset the plunger...but no write up on how to desemble the mc...
    1980 gs1000g "stock"
    There are 2 Philips screws in the bottom of the reservoir and then that comes off with a twist am pull, it is did friction fit at this point. Then you need to remove the rubber boot from around the end of the plunger. There may or not be a thin plastic washer under that. Next will be a snapring. I remove it with a pick otherwise you will need a thin long reach snapring pliers. Then you can pull/push out the plunger. Done.
    • windjammergump
      • Jan 2011
      • 71
      • shelby NC
      super nice JUDGE
      mine is nice but yours is the bomb but we both have issues mine are rings and pistons .....any leads to where to get pistons or gaskets for a top end job?gump
      windjammer gump
      bikes now own
      1981xs1100sh special
      1971 cb 350
      mini chopper project
      bikes use to own
      1978 750/four..
      1983kz1100 ltd
        Right Angled Snap ring Plier Set - Reaches in deep to remove clips when
        rebuilding master cylinders.
        • lee_dutcher
          • Apr 2009
          • 822
          • mason city iowa
          I didn't see any screws in there...humming guess I got to look a little harder.....here is the link to my last post...Mabel u can show me where the screws are? http://http://www.xs11.com/forum/showthread.php?t=31858
          • lee_dutcher
            • Apr 2009
            • 822
            • mason city iowa
            appreciate it gump.... yea just the mc this time around... gaskets are on eBay and piston as well
            • mack
              • 2411
              • Ontario, Canada
              master cylinder
              Lee my MC reservoir didn't have screws either it was pressed in place and the long cover screws helped hold it in place. If yours isn't leaking I'd just clean it and leave it alone. I tried to twist and pry mine out and all I accomplished was to cause a leak where one didn't exist before. Steel lake trout line or guitar strings will clean out the holes.
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
                On the Special models at least, there are no screws but the ones that hold the cover on, those go through the plastic reservior into the MC body to hold it all down. There is a rubber o-ring around the neck that is pressed down into the MC. you should be able to twist it around some, and then take a putty knife and pry the reservior up. If you can just twist it say 90 degrees, you can uncover the spooge hole and clean it and the supply hole into the MC out without removing the reservior.
                AS otheres have stated the kep to pulling the plunger is that bloody little C-clip way down in there. I used two rat tail files, I ground the tips where they go into a file handle down to fit the holes in the C-clip and used those to work it out.
                  That's right if your screws go all the way through the reservoir thee won't be any inside. Sorry I am having issues lately.
                    Its ok Nate, we all have issues some days. CRS, Oldtimers.....Jack Daniels!!
                      But I am only 27 and I don't drink!
                        The '78 (and at least some of the '79s) standard master cylinders have the reservoirs with the brass inserts and the two screws inside; all the specials and the later standards have the reservoir held on by the cover screws. There's two versions of the rear master cylinders too; same difference, but I'm not sure where the change came.
