MY 1978 XS chopper/ Custom
  • roccet
    • 102
    • bend oregon
    #91
    what do you think about this headlight.. ill make it bigger and one of the lights will be more forward ..
    1978 E XS1100 purchased for =$600.00
    crap load of time spent modifying it = Priceless
    My bike has the XS motor but can't really call it XS11
    (or at least it still looks like the XS motor)
    it has about 50% of the frame left from the XS bike
    • g15usmc
      • Nov 2010
      • 365
      • 29 Palms CA
      #92
      me thinks bigger!
      Daily Driver - '04 Suzuki Marauder 1600
      Project Bike - '79 XS1100 Special
      Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
      Ride Till You Die!
      "MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
      “Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
      "When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"
      • g15usmc
        • Nov 2010
        • 365
        • 29 Palms CA
        #93
        these are mean looking...
        Ride Till You Die!
        • roccet
          • 102
          • bend oregon
          #94
          those are mean but also means i need a fairing .. im going naked all the way..
            So use the BMW car lights, with the LED ring. Small top, large bottom. Should look good.
            NICE JOB so far!
            • roccet
              • 102
              • bend oregon
              #96
              NICE JOB so far!
              haha you read my mind i have been on ebay looking for that very thing..
              there are several options.. some knock off companies making a halo kit..
              • g15usmc
                • Nov 2010
                • 365
                • 29 Palms CA
                #97
                I was actually thinking u could just take the concept...one big on small, stack em or side by side...or even just offset as they are...only one side needed, take housing off from around it and make something from it...like the beemer idea though...
                Ride Till You Die!
                • roccet
                  • 102
                  • bend oregon
                  #98
                  yup im on it.. .on the search for two size projection lights..
                  • roccet
                    • 102
                    • bend oregon
                    #99
                    update
                    ok now im working on my riser again.. the last one was cool . i got alot of comments on it but didnt really fit the bike theme..
                    • roccet
                      • 102
                      • bend oregon
                      #100
                      just installed.. bad picture ill take more later.
                      • jwhughes3
                        • 2798
                        • Home of the Alamo
                        #101
                        you are right
                        That does fit the theme better. Looks good. I hate you BTW.
                        John
                        '81 XS1100H - "Enterprise"
                        • g15usmc
                          • Nov 2010
                          • 365
                          • 29 Palms CA
                          #102
                          I Dont know if you got your lights made yet or not, but i found these at walmart...they are just under 19 for each set...the bigger ones are 3 inch lights and the small are 2 inches...heres the pic
                          Ride Till You Die!
                            #103
                            Wish I had accesses to those tools!
                            • Eveready1100
                              • 539
                              #104
                              Hi Roccet. Love the work so far.
                              This is probably way too late to do anything about now, but I'd thought i'd put it up here for you to have a think about. The discussions about the braking forces on the trailing arm design have been rolling around in my head for a while.
                              My line of thinking would be to fit inside out Discs and calipers like Honda made for their CBX550's
                              and stick the caliper somewhere like in the diagram below.
                              I'm not saying that you should bolt brakes off a 550 onto your 1100 (mind you, it's not going to be a race bike ) but that this type of layout would transfer the brake torque off the caliper onto the trailing link and help negate the front end dive. Given your obvious engineering talent and creativity, I think something along these lines wouldn't be too hard a task for you.
                              Barring that, maybe some form of hydraulic antidive system activated by the calipers that pressurise the shocks under brake application.
                              Just ideas, mate. Good luck with your build. I'll be keenly watching
                              • roccet
                                • 102
                                • bend oregon
                                #105
                                John
                                I feel the love
                                I think im going to make a new frame with the same characteristics .
                                I already started with a skeleton idea.. I just wish i had actual specs of the original frame.. you know anyone that has already drawn the frame up?
