Okay, I finally got my hands on a pair of acct's from a Vmax. Had trouble installing at first, had to start both bolts together to line the holes up properly. BTW I waited for the gaskets ( ordered 2) to arrive and man are they thin. Was wondering if I could use Permatex silicone gasket maker instead. Anyway there is an annoying leak at the bottom, so I wound up ovetightning and stripping the lower hole
fortunately the acct came with slightly longer screws (I used the original ones) it bit and tightned up again, real careful this time. Still leaks though. Don't want to risk stripping again. What to do? Double up on gaskets or just use permatex?
