V-max/Venture vs Vision Tensioners
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    Okay, I finally got my hands on a pair of acct's from a Vmax. Had trouble installing at first, had to start both bolts together to line the holes up properly. BTW I waited for the gaskets ( ordered 2) to arrive and man are they thin. Was wondering if I could use Permatex silicone gasket maker instead. Anyway there is an annoying leak at the bottom, so I wound up ovetightning and stripping the lower hole fortunately the acct came with slightly longer screws (I used the original ones) it bit and tightned up again, real careful this time. Still leaks though. Don't want to risk stripping again. What to do? Double up on gaskets or just use permatex?
    BAMN!
    '81 XS1100H "Brutus"
      Do yourself a favor and pick up a tube of Yamabond sealer; way better than automotive silicon, and the only gasket you'll ever need to buy is a head gasket....
      • Nubian
        • Apr 2011
        • 467
        • The Big East
        I hear and obey wise one
        BAMN!
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          Forgive me but it sounds like you installed it wrong. Did you disassemble the whole thing first? You put the main body in first then the spring then the bolt. If you don't do it this way your plunger will be out WAy to far and you may damage something
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          mikes650 front fender
          led's gallore...
          renthal bars
          gold valve emulators
          vmax tensioner
          Rifle fairing
          • Nubian
            • Apr 2011
            • 467
            • The Big East
            That's the way I did it. Just as you described.
            BAMN!
            • Cobia
              • Jul 2007
              • 1587
              • Palm Beach County, Fl
              VMax are bolt ons
              Got a set from ebay about a year ago and they came with bolts, had to use the original bolts because those were too long. Installed them on the G and the J, disassembled, with a little RTV on the gasket, and then adjusted the plunger. Haven't had a lick of problems or leaks since. Great mod, very trouble-free, and it works!!
              1980G Standard, Restored
              Kerker 4 - 1
              850 Rear End Mod
              Automatic CCT
              1980GH Special, Restored
              '82 XJ1100 (Sold)
              • TomRodgers
                • Jun 2008
                • 492
                • La Porte Indiana
                does it matter if its the "front" or "rear" CCT off a Vmax?? t
                '81H (my first XS ) "Grey Ghost"
                4:1 Jardine w/ headerwrap
                Windjammer(wiring issues)
                New paint/brakes to come!!
                '80G FrankenBike (parts bike)
                '80G to fix "BlackSunshine"
                Stock Pilots/125 mains
                Pod filters; 4:1 Kerker??
                SS Brake lines w/ new M/C's
                LED Brake Lite
                Needs paint....
                  No it does not, they are the same.
                    Fronts the easiest to pull off. Rear one requires removing the airbox.
